| High Definition | HD-DVD | Blu-ray Firmware update now up to 3.0 for 2nd gen HD-A2/-D2/-A20/-XA2/-XE1Discuss Firmware update now up to 3.0 for 2nd gen HD-A2/-D2/-A20/-XA2/-XE1 in the HD World | Computers | Games | Media forum; Firmware update now up to 3.0 for 2nd gen HD-A2/-D2/-A20/-XA2/-XE1 Firmware 3.0 is out. I updated my XA2 a while ago with no problems seen since.
Big new feature is ... |
| | #1 (Link) | ||||
| Firmware 3.0 is out. I updated my XA2 a while ago with no problems seen since. Big new feature is that the 1080p HDMI shutdown bug is fixed for those who had problems. Also the fast foward lockup bug is fixed per some reports. The H.264 AVC video codec "jaggies" issue when doing 1080p24 output is now getting mixed reports. Some say it is fixed others say that only the old firmware version 2.7 does not have the problem. We need some more authoritative reports. I don't have a 1080p24 compatible HDMI (72 or 120 Hz refresh) display.Links for a download of a CD-R ISO image: http://tacp.toshiba.com/tacpassets-i...-XA2-3003N.zip http://tacp.toshiba.com/tacpassets-i...-A20-3003N.zip http://tacp.toshiba.com/tacpassets-i...D-A2-3003N.zip http://tacp.toshiba.com/tacpassets-i...firmwarev3.asp Quote:
Last edited by bobgpsr; 06-30-08 at 09:39 AM. Reason: added ISO download links for version 3.0 firmware update | ||||
| | #4 (Link) | |||
| Re: Firmware update 2.0 for 2nd gen HD-A2/-D2/-XA2 So far I haven't seen a need to do an update on my A2. I registered it with Toshiba and based on my brother's experience with his A1 and doing firmware updates, I personally will wait for the disc to be sent from Toshiba. Like I said, right now I don't see a need to download and burn a disc so I can wait ![]() "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||
| | #5 (Link) | |||
| Re: Firmware update 2.0 for 2nd gen HD-A2/-D2/-XA2 A new firmware disc (2.3) is about to come out anyway. It will add to the internet functionality that is just starting to come out. Version 2.3 has already been given to some advance people such as reviewers etc.. | |||
| | #7 (Link) | |||
| Re: Firmware update 2.0 for 2nd gen HD-A2/-D2/-XA2 Yes it is now on the Toshiba Canada site see post: http://www.hometheatershack.com/foru...html#post35060 | |||
| | #9 (Link) | |||
| Re: Firmware update 2.0 for 2nd gen HD-A2/-D2/-XA2 Firmware version 2.3 is now released for the HD-XA1, HD-A1, and HD-D1 players - Improves network connectivity - improves certain video and audio processing capabilities - addresses certain disc playback and HDMI/DVI issues | |||
| | #10 (Link) | |||
| Re: Firmware update 2.0 for 2nd gen HD-A2/-D2/-XA2 BTW here is the link to download firmware updates from tosh if you are looking to download the ISO directly to a PC and then burn it to a CD. This is for all player versions, after you select the user agreement you will then be asked to select which player you have. Download Firmware Updates | |||
| | #11 (Link) | |||||
| | Re: Firmware update 2.0 for 2nd gen HD-A2/-D2/-XA2 Quote:
| | #12 (Link) | |||
| The Toshiba Canada website: http://209.167.114.38/support/ceg/downloads/ now has version 2.1 firmware for the 2nd gen models. I downloaded and burnt. Reprogrammed my XA2 with 2.1 f/w and played "Being John Malkovich" without any issues. Not sure yet what the 2.1 update did. I do use only component video for connection though. Last edited by bobgpsr; 07-30-07 at 10:17 PM. Reason: update info after f/w update | |||
| | #13 (Link) | |||
| Re: Firmware update 2.0 (& now 2.1) for 2nd gen HD-A2/-D2/-XA2 Can someone help out a computer challenged guy? I've downloaded the update and when I try to do anything I get the file format is invalid or unsupported error message. I've redownloaded and tried everything I know/ Can anyone help me out? | |||
| | #14 (Link) | ||||
| Re: Firmware update 2.0 (& now 2.1) for 2nd gen HD-A2/-D2/-XA2 Quote:
The update is now available to directly update the player using the ethernet connection. That may be a lot easier for you. Don't need to burn a CD that way. | ||||
| | #16 (Link) | |||
| Firmware update now at 2.2 for 2nd gen HD-A2/-D2/-XA2 It appears that firmware 2.2 for the 2nd gen Toshiba HD DVD players is out. My XA2 is updating over the ethernet port right now. Hope this thunderstorm doesn't kill power during the last 5 programming steps -- living dangerously! ![]() | |||
| | #18 (Link) | |||
| Re: Firmware update now upto 2.2 for 2nd gen HD-A2/-D2/-XA2 I just installed the 2.2 update on mine. Since I had just done the 2.1 last night and hadn't watched a movie can't say for sure what this update did. I will say that one of these improved the boot time and took care of the audio sync problem I had. I'm loving this machine. | |||
| | #19 (Link) | |||
| Re: Firmware update now upto 2.2 for 2nd gen HD-A2/-D2/-XA2 SteveB, can you elaborate on the audio sync problem, are you using analog or HDMI for audio?? I have a sync problem with analog, running firmware 1.5 at the moment. Hakka. edit: just realised you were in the Xa2 sync thread, using analogs if I remember correctly. I will update tonight. | |||
| | #20 (Link) | |||
| Re: Firmware update now upto 2.2 for 2nd gen HD-A2/-D2/-XA2 Hakka, I'm using analog and was using firmware 1.5 when I had the audio sync problem. Either 2.1 or 2.2 cleared up the sync. On mine the audio was running ahead of the video but it's all better now. | |||
| | #21 (Link) | |||
| Re: Firmware update now upto 2.2 for 2nd gen HD-A2/-D2/-XA2 Tried to update last night but as soon as I clicked 'yes' I got an error code 2007c5b2. I burned with nero, I remember reading some people were having probs when burning with nero. Hakka. | |||
