Toshiba A2 audio ? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray
Toshiba A2 audio ?
Discuss Toshiba A2 audio ? in the HD World | Computers | Games | Media forum; Toshiba A2 audio ? Hi, I just recieved my A2 today, got everything setup using component for video ( no hdmi on projector) and ...
Old 07-16-07, 07:45 PM   #1 (Link)
Alias: mike
Loc: Olney, Illinois
mikeb's Avatar
User: #3292
Since: Oct 2006
mikeb is offline
Toshiba A2 audio ?
Hi, I just recieved my A2 today, got everything setup using component for video ( no hdmi on projector) and optical to reciever for audio set to bitstream on the A2. Everything works great but my Yamaha reciever shows DTS on both of the HD DVD's that I have even though they are Dolby Digital only. Any help would be greatly apreciated as I can't seem to figure the reason out.
Thanks
Mike
Old 07-17-07, 07:43 AM   #2 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is offline
Re: Toshiba A2 audio ?
For HD DVD the player must decode any audio codec used on an Advanced Content HD DVD title (most all HD DVD's are authored as Advanced). The player then mixes the audio with button sounds and with PiP (HDi) commentary audio. The HD-A2 then re-encodes the resulting audio as legacy 1509 kbps dts to send out the S/PDIF (coax or optical Toslink) interface which is what an AVR will show (dts).
Old 07-17-07, 11:32 AM   #3 (Link)
Alias: mike
mikeb's Avatar
User: #3292
Since: Oct 2006
mikeb is offline
Thanks Bob, just wanted to make sure this is what it was supposed to be doing. :holycow:
Old 07-18-07, 11:23 AM   #4 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Interesting. Mine's on its way now. My receiver (Marantz SR-18) can do DTS and DD, but I can't apply the THX re-eq on DTS. Is their any way to downmix it to Dolby instead?
If not, I'm not too concerned. The days of the SR-18 in the theater are numbered. As soon as I can convince the wife to spend a mortgage payment on a new preamp that will do TrueHD
Old 07-18-07, 12:04 PM   #5 (Link)
Tech'y Shackster
Alias: Bob
User: #25
bobgpsr is offline
Do thorough research before buying a "TrueHD" decoder capable preamp. What will be your Dolby TrueHD bitstream source? It will require HDMI 1.3 which only the HD-XA2 has at the moment (for HD DVD players). Also even the HD-XA2 will not output TrueHD bitstream right now -- rumours are that a Fall firmware update may allow it as an audiophile option.
Old 07-18-07, 12:17 PM   #6 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
So the only way the HD-A2 sends out its TrueHD et al. is by recoding it in DTS or DD over the Toslink?
Old 07-18-07, 12:42 PM   #7 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Okay, I just read the manual online.
Basically it sends everything DTS over the SPDIF/optical cable. If you have an HDMI audio enabled receiver, it will send up to the 5.1 TrueHD,etc over the HDMI. It just won't send the whole bitstream.
Not to worry, I only have four speakers and subwoofer anyway
Old 07-18-07, 02:59 PM   #8 (Link)
Tech'y Shackster
Alias: Bob
User: #25
bobgpsr is offline
Anthony wrote: View Post
If you have an HDMI audio enabled receiver, it will send up to the 5.1 TrueHD,etc over the HDMI. It just won't send the whole bitstream.)
For Dolby TrueHD there is nothing wrong with having the player do the decode and then use lossless multichannel linear PCM (not bitstream) via HDMI to get the sound to the receiver.
Old 07-18-07, 03:04 PM   #9 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
I thought I read in the manual that it could only encode 5.1 channels of whatever it was fed to send over HDMI. Something about core DTS (my eyes had glazed over by then).
It sounds like it will be fine. Even like this over the Toslink cable, it will be a monumental improvement over my current setup.
Thanks for the info.
Old 07-18-07, 05:43 PM   #10 (Link)
Alias: mike
mikeb's Avatar
User: #3292
Since: Oct 2006
mikeb is offline
Very informative discussion, thanks!
Old 08-28-07, 10:16 AM   #11 (Link)
Alias: Zip
Loc: Canada
MatrixDweller's Avatar
User: #10408
Since: Jul 2007
MatrixDweller is offline
If you play a standard DVD the audio is passed in whatever format you choose and does not only display as DTS.
Old 09-25-07, 09:16 PM   #12 (Link)
Alias: thxgoon
Loc: colorado
thxgoon's Avatar
User: #6924
thxgoon is online now
So MikeB, now that you've had this player for a while what do you think of it? How does it look via component? Does the audio via DTS sound as good as traditional DTS dvd's?
« Home Theater Shack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray »
Similar Threads
Toshiba HD A2 for Under $300 spyboy High Definition | HD DVD | Blu-ray 6 05-22-07 08:15 AM
Toshiba lcaillo Manufacturer and Vendor Reference Information 0 05-01-07 07:51 PM
FS: Toshiba HD-A2 plincoln Classifieds - Video Components 0 04-08-07 12:34 PM
Calibrating the Toshiba HD-XA2 5.1 analog audio outputs bobgpsr High Definition | HD DVD | Blu-ray 3 02-27-07 12:50 PM
Just ordered a Toshiba HD-A1 FlashJim High Definition | HD DVD | Blu-ray 27 10-25-06 12:37 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
