[HD-XA2] Setting up analog 5.1??? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray
Discuss [HD-XA2] Setting up analog 5.1??? in the HD World | Computers | Games | Media forum; [HD-XA2] Setting up analog 5.1??? Hi All, I just got my XA2 and I was setting up the analog 5.1 so I can benefit from ...
Old 09-26-07, 09:09 AM   #1 (Link)
Alias: cruz
User: #9913
Since: Jul 2007
cruzmisl is offline
Hi All,
I just got my XA2 and I was setting up the analog 5.1 so I can benefit from Dolby TrueHD. I was setting up the speakers in the player and I have a question on the speaker calibration.
The only option for levels is 0 to -12dB. The sub level is about 4-6dB lower than the mains/surrounds but I can't raise it through the DVD player. What's the best way to level out the settings? Should I reduce the others by 4dB or so to match?
Any suggestions? I'm not sure how accurate the internal test tones are. I could use my avia disc but it would take 5 times as long.
Thanks,
Joe
Old 09-26-07, 11:43 AM   #2 (Link)
Alias: Royce
Loc: Victorville, CA
User: #49
RollsRoyce is offline
Re: [HD-XA2] Setting up analog 5.1???
My XA-1 has the same issue. About the only thing you can do is to use your sub at 0 as the reference and reduce the others to that as you mentioned. If your receiver or pre-pro allows you to set the sub and other speaker's levels on a per-input basis as my old Pioneer used to, then you can do that instead of or in addition to the player's setup.
---Royce---
"I never drink...wine..." Bela Lugosi, DRACULA, 1931
Old 09-26-07, 11:49 AM   #3 (Link)
Alias: cruz
User: #9913
Since: Jul 2007
cruzmisl is offline
Thanks! I don't think my MMC-1 has that ability I guess I'll just bring the other levels down.
Old 09-26-07, 06:13 PM   #4 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is offline
What I do for both my XA1 and my XA2 is to set the player's sub/LFE at 0 dB and all the other chans -5 dB down (although these chans can be tweaked). Then I boost the sub level another 10 dB at the sub's amp input gain control - not the AVR/Pre-Pro. Must use disc based test tones -- the players' test tones are messed up. After getting the 6 chan direct input calibrated, I then select a S/PDIF or other two channel input on the AVR and then have the AVR do another calibration (to get the internal to AVR sub level back down to cal). The speaker distance settings in the player should repeat what the AVR/Pre-Pro has set. Note that the above is for a AVR/Pre-Pro that does not re-digitize the 6 channel analog inputs and setting all speakers to SMALL in the player.
This is to get the normal +10 dB LFE boost plus the needed additional +5 dB boost when the player re-directs SMALL set chans to the sub/LFE channel. Have to do exactly the same thing for most DVD-A/SACD player's analog outputs also. Just a normal thing to do for audio industry practices.
For the XA2 you must have the player's internal SETUP menu have the SPDIF set to PCM. Kinda a XA2 bug. Otherwise the SMALL set chans do not get proper low freq crossover to the sub added to the sub/LFE channel. Yes, this is a bug workaround.
Old 09-26-07, 06:22 PM   #5 (Link)
Alias: cruz
User: #9913
Since: Jul 2007
cruzmisl is offline
So I would be best to use my avia test disc? I'm a bit confused about spdif output. Will setting it to PCM affect when I watch a regular DVD through the toslink?
Old 09-26-07, 07:40 PM   #6 (Link)
Tech'y Shackster
Alias: Bob
User: #25
bobgpsr is offline
cruzmisl wrote: View Post
Yes Avia works very well.
If you really feel that you want to use Toslink to your AVR when playing a standard DVD, then yes, you need to go through the hassle of setting the player's SPDIF back to BITSTREAM to get 5.1 or 6.1 decoded by your AVR.
But the player does have DD and dts decoders so you could leave your set up to always use the 5.1 analog player outputs.
« Home Theater Shack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray »
Similar Threads
Decent Analog>HDMI jackstraw Home Theater Components 16 09-15-07 06:36 PM
Calibrating the Toshiba HD-XA2 5.1 analog audio outputs bobgpsr High Definition | HD DVD | Blu-ray 3 02-27-07 12:50 PM
Toshiba HD-XA2!!! jagman High Definition | HD DVD | Blu-ray 7 09-20-06 08:09 AM
Digital Vs Analog Danny General Discussion 4 07-29-06 03:59 PM
weird problems when using with RS analog meter winggee REW Forum 4 06-09-06 05:59 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191
