PS3: Component vs HDMI - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray
Discuss PS3: Component vs HDMI in the HD World | Computers | Games | Media forum; PS3: Component vs HDMI With my PS3 is there a performance degradation by going with component cables instead of HDMI?...
Old 10-21-07, 12:01 AM   #1 (Link)
Alias: Motegi
Loc: Michigan
User: #12630
Since: Oct 2007
Motegi is offline
Old 10-21-07, 10:23 AM   #2 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is online now
Re: PS3: Component vs HDMI
Motegi wrote: View Post
A lot depends on the type of display you have. If it is CRT based then not so much. Other types like LCD, plasma or DLP may be worse with component video versus using a digital HDMI connection.
Old 10-21-07, 01:43 PM   #3 (Link)
Alias: Motegi
Loc: Michigan
User: #12630
Since: Oct 2007
Motegi is offline
Thanks for the reply!
I have an LCD flat panel and am currently using HDMI on my PS3 but I also have the Sony Component cables as well and just wanted to see what others experience was with them..
Old 10-21-07, 02:20 PM   #4 (Link)
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
cynical2 is offline
bobgpsr wrote: View Post
Similar situation...
How about with the front projection LCD (Panny AX-100U) in our HT? My son wants a PS3, but my receiver is out of room for additional HDMI connections. So, I will have to:
(1) Hook up the PS3 via component,
(2) Move my DirecTV HR20-700 HD-DVR from HDMI to component to make room for the PS3's HDMI connection, or
(3) Move my Toshiba HD-A2 HD-DVD player from HDMI to component to make room for the PS3's HDMI connection.
Thoughts on the best approach based on the sources?
FYI, HT receiver is an Onkyo TX-SR605, and I have both component and HDMI run via 35-ft Monoprice cables...currently nothing is being fed through the component connection to the projector.
Thanks!
Old 10-21-07, 05:26 PM   #5 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
wbassett is online now
The best way to determine it is just give it a whirl. Temporarily locate the PS3 closer to the projector so you don't have to get super long cable. Check Monoprice and RiteAV, for $12 you can get a 12' component cable and 10' HDMI cable. That should give you enough room to get the PS3 close enough for a test before getting a cable long enough for normal placement. I wouldn't worry about sound, you just want to test the image quality.
I have a friend that bought a the same Sony SXRD set I have and he was complaining to me that he hated it, saying he PQ was horrible. After talking to him I found out he was using component and I was using HDMI. I haven't talked to him in awhile to see if he tried HDMI out, but my PQ is stunning.
As Bob said, some displays look better with one connection than another. I'd give it a test with both and see, the cables are pretty inexpensive through both of these companies. I ordered through RiteAV and had my cables two days later.
« Home Theater Shack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray »
Similar Threads
HDMI vs. Component Sonnie Remotes | Cables | Accessories 9 03-17-07 12:39 AM
HDMI Twins: Is BetterCables Selling an $89 HDMI Switcher for $350? geekwithfamily Home Theater, Audio and Video News 2 02-27-07 11:11 AM
Ghetto component ventilation toecheese Home Theater Design and Construction 1 12-12-06 10:55 PM
Component, DVI and HDMI over CAT-5 Roger Home Theater, Audio and Video News 0 05-24-06 01:33 AM
Component, DVI and HDMI connections Roger Home Theater, Audio and Video News 0 05-09-06 06:32 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
