Should i buy the HD-XA2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray
Discuss Should i buy the HD-XA2 in the HD World | Computers | Games | Media forum; Should i buy the HD-XA2 I currently have a hd-a1 and would like a second hd-dvd player. I read a lot of reviews on the ...
Old 11-07-07, 10:49 AM   #1 (Link)
Alias: Steve
Loc: Bend, Oregon
User: #9843
Since: Jun 2007
  devicente is offline
Question Should i buy the HD-XA2
I currently have a hd-a1 and would like a second hd-dvd player. I read a lot of reviews on the hd-xa2 and it looks
seems to stand out. I found one for 399.00 at best buy. I don't know if i should go with the HD-a35 for the same
price or just wait for the next thing. For the price i think i may be worth it. Please advise.
Thanks.
Old 11-07-07, 03:39 PM   #2 (Link)
New Member
Alias: rd
Loc: Miami, FL
User: #13187
Since: Nov 2007
  rdjam is offline
Re: Should i buy the HD-XA2
Absolutely, yes.
The XA2 is my current Favourite HD DVD player.
Excellent build quality, solid heavy, and the REON HQV processor is stellar.
The 1080p24 "glitch" is guaranteed to be fixed within weeks, so this should not be a consideration during purchase. And, of course, the ability to play regular DVDs at 1080p24 is totally unique to any HD players.
I just love this unit, and it's not due to be replaced until long into next year (the A35 is not a replacement for the XA2).
So, the answer is: Yes!
Old 11-07-07, 03:47 PM   #3 (Link)
Loc: L.A. (Lower Bama)
Yep... I agree! Excellent player! That is also a very good price.
Welcome to the Shack!
Old 11-07-07, 06:06 PM   #4 (Link)
Alias: Worm
Loc: Colorado
User: #7339
Since: Mar 2007
  Big Worm is offline
Both units are good. The one thing that the A35 has over the XA2 is that the A35 can send out the bitstream data to allow your receiver to do the processing of the latest codecs.
Basically if you have the latest receiver so as a Onkyo 605 you get to have your receiver light up saying "TrueHD" as opposed to PCM. In the end it does not make a difference.
But if it were me and you could actually find a XA2 for $399, I would get that one.
Old 11-08-07, 01:22 AM   #5 (Link)
Alias: Steve
Loc: Atlanta, GA
SteveB's Avatar
User: #3208
Since: Oct 2006
  SteveB is offline
I have a XA-2 also and love it. Get it, upgrade the software and enjoy.
Old 11-08-07, 01:48 AM   #6 (Link)
Alias: Steven
Loc: lake ozarks MO
thewire's Avatar
User: #9828
Since: Jun 2007
  thewire is offline
Yes. It is a good unit.
Old 11-08-07, 06:54 AM   #7 (Link)
Alias: Richard W. Haines
Loc: Croton-on-Hudson, NY
Richard W. Haines's Avatar
User: #10054
Since: Jul 2007
  Richard W. Haines is offline
It's a good unit but not if you have 5.1 analog sound like me. When you watch standard DVDs upscaled
you might have sound problems of the synch drifting in and out if you're using the HDMI cable for both
player and DLP projector. I also had a problem outputting "The Wild Bunch" HD DVD to 1080p. It only
plays back 1080i on my projector from this Toshiba machine. I don't know if it's a problem with the player or my DLP. In any event, it's not quite as easy to use as a standard DVD player. It takes a while to navigate. I had to push the remote button a few times to get to the menu so I could alter
the Picture output in the various settings of 720, 1080i and 1080p. Either that or I'm just not use
to the delayed action in this format. You'll need some patience if you're used to instantaneous results with a remote.
I paid $544 for it from Amazon. I had problems with the transaction. I sent them
a postal money order which they claimed they never received so I went to the post
office to track it and/or cancel it (which takes a couple of months) and then paid
for it via credit card. By the time that went through, they had lowered the price
to $500 so I got stuck paying an extra $44. I bought my Optoma HD70 projector
from Circuit City as I mentioned in another post and it had a dead pixel which
they wouldn't handle for me. I had to contact Optoma directly and am waiting to
hear back from them to replace the projector. My experience with Circuit City
in Cordlandt, New York was a bad one. Their customer service is the pits at least in that location.
Old 11-08-07, 08:43 AM   #8 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
  bobgpsr is offline
Richard W. Haines wrote: View Post
I have the XA2 working very very well with the 5.1 analog outputs. It calibrates just like most other SACD/DVD-A players once you find the odd idiosyncrasy that you have to set the SPDIF to PCM in order for the analog out bass management to work.
The required external +15 dB boost to the sub/LFE channel (that most all such 5.1 analog output players require) can be tricky but it is doable. The gain boost needed is +5 dB over the standard LFE +10 dB because of the bass management being done in the player with the main/center/surround speakers set to SMALL. I am happy with my two systems that use the 5.1 analog outputs, one with a XA1 and another with a XA2. Decent subwoofers with both systems.
We can start a new thread on 5.1 analog calibration procedures/techniques for those who are having sound (esp LFE) calibration issues with the HD-XA2. Should we?
Old 11-08-07, 09:18 AM   #9 (Link)
User: #10054
Since: Jul 2007
Yes.
Old 11-08-07, 10:09 AM   #10 (Link)
Tech'y Shackster
Alias: Bob
User: #25
  bobgpsr is offline
Yes.
Ok, I try to get around to that later tonight. In the meantime look for hints in this post: http://www.hometheatershack.com/foru...html#post31915
Oops! We already have such a XA2 analog audio setup thread:
http://www.hometheatershack.com/foru...html#post52816
Last edited by bobgpsr; 11-08-07 at 12:01 PM.. Reason: udated to reference setup thread.
Old 11-08-07, 12:02 PM   #11 (Link)
Tech'y Shackster
Alias: Bob
User: #25
  bobgpsr is offline
bobgpsr wrote: View Post
Oops! Already have such a thread:
http://www.hometheatershack.com/foru...log-5-1-a.html
Old 12-27-07, 04:38 AM   #12 (Link)
User: #10054
Since: Jul 2007
I received a CD-Rom of the firmware update, installed it and it corrected the synch problem
so at this point in time I'll recommend the player but make sure you have the update to
avoid some bad early screenings like me.
One other minor problem with the machine. There was a digital glich on one of the discs
of the first season of "The Rockford Files" where the image broke up but then continued
to play. The Toshiba locked on the glich and wouldn't play it at all. I tried the disc in
my Samsung player and it was able to bypass the glich and continue with the show.
I don't know if the Toshiba is more sensitive to gliches for standard DVDs than other
players but I thought I'd mention it.
« Home Theater Shack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray »
Similar Threads
Head Phones, Where to buy, What to buy? olddrum1 HiFi Audio Components 21 01-04-08 10:03 AM
[HD-XA2] Setting up analog 5.1??? cruzmisl High Definition | HD DVD | Blu-ray 5 09-26-07 08:40 PM
WooooHoooo Finally got my XA2 SteveB High Definition | HD DVD | Blu-ray 2 07-26-07 08:32 PM
To buy or not to buy...1124P vs 2496??? blazerman BFD Forum 16 04-18-07 06:20 PM
Toshiba HD-XA2!!! jagman High Definition | HD DVD | Blu-ray 7 09-20-06 09:09 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164
