Receiver question with XA-2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray
Discuss Receiver question with XA-2 in the HD World | Computers | Games | Media forum; Receiver question with XA-2 OK, not sure if this is the right place to post this or not but it's something I've been thinking ...
Old 11-20-07, 12:13 AM   #1 (Link)
Alias: Steve
Loc: Atlanta, GA
SteveB's Avatar
User: #3208
Since: Oct 2006
SteveB is online now
OK, not sure if this is the right place to post this or not but it's something I've been thinking about. Yes, I admit it, I'm a noob to HT . I have a HK AVR 435 hooked to my XA-2 and use the 5.1 analog connection. With this connection the display on my receiver shows 6 channel direct and I know that everything is working correctly.
My question revolves around the fact that by using this connection I have no control over anything in my receiver, ok other than volume. The receiver doesn't show me what kind of sound is being output. Does it sound like I am getting the best surround sound that I can? I know I could unhook everything and hook up a fiber cable to use the other decoders(?) like Prologic, Neo etc. Does anyone know if by using this connection I am getting true HD sound, or as close to it as I can with this receiver? There is no HDMI connection available.
Thanks for any info you guys can offer.
Steve
Old 11-20-07, 07:56 AM   #2 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is offline
Re: Receiver question with XA-2
That is the best quality 5.1 channel lossless audio sound connection you can do with your HD 435 AVR. When you select a Dolby TrueHD track on a HD DVD the player decodes it, converts it to analog using Burr-Brown 192kHz/24bit DACs and sends it to your AVR. For more info read this.
You do need a +10 dB boost on your subwoofer for a 5.1 analog connection. Read this and this for more about that.
Old 11-21-07, 12:33 AM   #3 (Link)
Alias: Steve
Loc: Atlanta, GA
SteveB's Avatar
User: #3208
Since: Oct 2006
Thanks Bob.
As usual you come through with the answers. Actually I had read the posts you linked. I just checked the boxes on the HD DVDs I have and only one (300) that has TrueHD listed as an option on the label The others showed Dolby Digital or Digital Plus. So I guess that using the 5.1 connect is still the best route to go.
« Home Theater Shack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray »
Similar Threads
Which receiver? paulspencer Home Theater Components 41 11-08-07 10:59 PM
Looking for a receiver... billmd Home Theater Components 2 10-28-07 12:15 PM
Yamaha RX-V1700 Receiver / RX-V2700 Receiver - Official Owners Thread Sonnie Home Theater Components 88 09-18-07 10:41 AM
Looking for an HD Receiver Jay High Definition | HD DVD | Blu-ray 4 12-30-06 03:49 PM
Receiver Recommendations Darrel Hawthorne Home Theater Components 16 07-19-06 04:34 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
