LOTR Special Edition 4 Disc Set... - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray
Discuss LOTR Special Edition 4 Disc Set... in the HD World | Computers | Games | Media forum; LOTR Special Edition 4 Disc Set... Okay I am going to pose a question... Granted SDVD players cannot meet the resolution standards of either BD or ...
Old 12-30-07, 02:36 AM   #1 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
wbassett is offline
Granted SDVD players cannot meet the resolution standards of either BD or HD DVD, do you think the four disc collectors set of Lord of the Rings (all three) is as close to High Def as you can get with SDVD?
Considering HD DVD has a different codec and compression format than what BD currently uses (for most content) and HD DVD can fit High Def on one 15GB single layer disc, the LOTR movies in the special edition come on two dual layer SDVD discs, which comes out to around 16GB for each movie. The movies are long, that's for sure, but they could have put them on one dual layer SDVD. Since they split the movie on two dual layer SDVD discs, is this as good as it gets with Standard Def? Upconverted these movies look stunning. I've seen some HD DVD and Bluray discs that paled in comparison, but like we always say, it's all in how well the disc was mastered.
I have the T2 extreme DVD that comes from a 1080p master and it does look better than my older two disc T2 collector's Edition.
Back to the earlier comment that SDVD cannot match the resolution of HD players, but if it is mastered from a High Def source and played back on a top notched player that upconverts extremely well... how many feel this is comparable to High Def? I am not saying this is 'true' High Def, just posing the question of how good can SDVD be when played back on a High Def upconverting player?
The reason I pose this question is SDVD really is still the format king and if they produce DVDs from flawless masters could they keep a foot hold in the format war? I say yes they can. I watched Walk in the Clouds and there were scenes that truly looked 3D. It looked so good that I actually forgot it was an SDVD in the player.
I also have Troy in SDVD, the original HD DVD release, and then the remastered HD DVD release. Between the SDVD and original HD DVD version, I was disappointed in HD DVD. Between the two I did not see enough difference to warrant the double dip, but at the triple dip mark, the remastered High Def version blew the other two away. Still the question is, can SDVD hang on throughout the 'war' and for how long?
Old 12-30-07, 10:28 AM   #2 (Link)
Alias: Maverick
Loc: Sandnes, Norway
User: #7168
Since: Mar 2007
atledreier is offline
Re: LOTR Special Edition 4 Disc Set...
Well... On my television (40" LCD) the upconverted DVDs look great, and not THAT big a difference to HD. On a bigger screen (80") the difference is huge.
Old 12-30-07, 06:04 PM   #3 (Link)
Alias: Wayde
Loc: Waterloo ON, Canada
Wayde's Avatar
User: #943
Since: Jun 2006
Wayde is offline
comparing scenes in LOTR from my SD-DVDs to the HD releases found on HD-PPV and movie channels on cable TV.
The real difference is when there are wide panoramic shots. It's just not even close. I used my splic screen once to show the difference to friends. The exact same frame saved on a PVR'ed HD version and the same from on the SD-DVD. Although SD-DVD looks very good... it's those panoramic shots and there are plenty on LOTR. They just look breathtaking on HD.
Wayde
Old 12-30-07, 08:26 PM   #4 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
wbassett is offline
Just got cable again after three years and haven't seen them on HD, but that's a good comparison Wayde.
The big thing I was curious and thinking about was with the movie being on two discs they could pump up the bit rate and quality to as good as it gets for SDVD and then when upconverted...
Old 12-31-07, 02:27 AM   #5 (Link)
Alias: MrPorterhouse
Loc: North Ridgeville, OH
MrPorterhouse's Avatar
User: #1797
MrPorterhouse is offline
wbassett wrote: View Post
Well, DVD is capped at 480P and that means that you can't "pump up" the bit rate, except for needless use of data. The only way to increase true quality is to increase the resolution. A true high rez signal will always look better than a lower rez signal of the same master. Upconverts can look absolutely stunning on those smaller sceens of less than 42" or so, but once you go big screen of 65"+, there is no comparison, really. If you have a screen less than 42", then a good upconverted DVD will hold you nicely.
Old 12-31-07, 06:31 PM   #6 (Link)
Alias: Wayde
Wayde's Avatar
User: #943
Since: Jun 2006
Wayde is offline
I wonder how they'll arrive on HD DVD. Will they release the director's cuts or the theatrical first like they did the DVDs?
Wayde
Old 01-01-08, 03:44 PM   #7 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
wbassett is offline
My guess is the theatrical version first and then the deluxe super edition director's cut extended extended version later to get the double dip.
I'll only be buying the special edition though when it finally comes out on High Def.
« Home Theater Shack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray »
Similar Threads
Transformers Special Edition HD DVD Review Wayde Media Reviews 11 12-03-07 02:43 PM
What's with collector's edition DVDs MatrixDweller Movies | TV Shows | Hollywood 11 09-07-07 08:45 AM
"The Sand Pebbles" Special Edition review Richard W. Haines Movies | TV Shows | Hollywood 0 07-11-07 05:23 AM
LotR Limited vs. Extended nova Movies | TV Shows | Hollywood 9 06-01-07 05:08 PM
Which LOTR has the ringdrop scene? Exocer Movies | TV Shows | Hollywood 4 05-21-06 12:08 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
