Quickie! - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray
Quickie!
Discuss Quickie! in the HD World | Computers | Games | Media forum; Quickie! Can any decent HDDVD or BluRay players send the super trick, lossless sound formats over a set of RCAs to ...
Old 01-03-08, 07:59 PM   #1 (Link)
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
  yourgrandma is offline
Quickie!
Can any decent HDDVD or BluRay players send the super trick, lossless sound formats over a set of RCAs to my 7.1 input? IOW, do they have onboard processing?
I'm not in the market for a new receiver, so even this would be a comprimise, because I'd have to either get a switch, or lose DVD-A/SACD. (That's not gonna happen)
WHat do the folks running previous generation AVR's do with their audio feed? Does it just convert to DTS ES Discreet or DD EX?
Geesh, maybe thats not so quick.
Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3
Old 01-04-08, 11:31 AM   #2 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
  bobgpsr is offline
Re: Quickie!
The first gen HD DVD players (HD-A1, HD-D1, HD-XA1, HDV5000), the HD-XA2, the HD-A35 and the DV-HD805 all have 5.1 analog outputs. To drive a 7.1 input, many of us put Y splitters on the surround inputs (side & back surround). Then you need to configure a +10 to +15 dB boost for the .1 LFE channel so reference thread http://www.hometheatershack.com/foru...log-5-1-a.html for how to setup for this.
Some of the Blu-ray players also have analog outputs IIRC.
Old 01-04-08, 04:37 PM   #3 (Link)
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
Re: Quickie!
Just 5.1, huh?
I was only wondering because I can't decode the new audio formats and wanted to see if the player could. I did a little bit of research and found what you stated to be true. Do most titles also have a 6.1 track, or does the receiver just process it like the older tracks?
Old 01-06-08, 10:54 AM   #4 (Link)
Tech'y Shackster
Alias: Bob
User: #25
  bobgpsr is offline
Re: Quickie!
The players do not decode a 6.1 track -- but when sent on to AVR via the lossy codec re-encode on SPDIF -- the AVR can apply (if user "forces" on) EX, ES or PLIIx processing to matrix decode recover the back channel surround channels from the side surrounds.
Old 01-06-08, 12:41 PM   #5 (Link)
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
Re: Quickie!
I 'spose it'd just be easyest to run an optical and take whatever it gives me then, huh?
Old 01-06-08, 04:16 PM   #6 (Link)
Alias: MrPorterhouse
Loc: North Ridgeville, OH
MrPorterhouse's Avatar
User: #1797
  MrPorterhouse is offline
Re: Quickie!
yourgrandma wrote: View Post
Yes, some do. What would fit your needs would be the Panasonic Blu-ray player, model DMP-BD10AK. This is the previous model for Panasonic, the current being the DMP-BD30K. The BD10 has onboard audio decoders for Dolby Digital Plus and Dolby True HD and DTS HD(but not DTS Master, which it converts to the still very good DTS core). This model has 7.1 analog outputs, so it would be backward compatible with older receivers that don't have HDMI.
http://www2.panasonic.com/consumer-e...702#tabsection
« Home Theater Shack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
