| High Definition Media Do Blu-ray discs have an industry standard reference level?Discuss Do Blu-ray discs have an industry standard reference level? in the HD World | Computers | Games | Media forum; Do Blu-ray discs have an industry standard reference level? I notice that I generally play my blu-rays at the same volume level of my master volume. This wasn't the ... |
Views: 200 - Replies: 5
| Do Blu-ray discs have an industry standard reference level? I notice that I generally play my blu-rays at the same volume level of my master volume. This wasn't the case with DVDs. They were always all over the place. Some are mastered really much hotter than others. Blu-rays appear more consistent. Does anyone else notice this? Is there an industry standard? | ||||
| | #2 | ||||
| Re: Do Blu-ray discs have an idustry standard reference level? Don't have a blu-ray but are you sure you don't have the night time viewing setting turned on? ![]() Regards, Wayne | ||||
| | #3 | ||||
| Re: Do Blu-ray discs have an industry standard reference level? The terminology "refference level" is more a standard level that you run your system at (75db at the listening position) not the level it has been masterd at. It almost sounds like your settings are not correct, you have a "night mode" listening mode or dynamic compression in the DVD player turend on? The only real big difference between the audio on DVDs and Blu Ray is with the uncompressed formats there will be a little bit more dynamics. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #4 | ||||
| Re: Do Blu-ray discs have an industry standard reference level? I guess reference level is the wrong term. I was simply stating that my normal listening level seems to be the same for blu-rays, vs on dvd it was all over the place. | ||||
| | #5 | ||||
| Re: Do Blu-ray discs have an industry standard reference level? Older DVDs were a bit wonky due to the mastering being less than standard. Are you using a different player for BluRay movies than for DVDs? Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #6 | ||||
| Re: Do Blu-ray discs have an industry standard reference level? Right now, I am, but same results in the past with a separate DVD player. Not really a problem, just a curiosity. I know for sure that DVDs are all over the place as far as how hot they are recorded...just curious if others are finding that blu-rays are more consistent. | ||||
