ceiling treatments - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
ceiling treatments
Discuss ceiling treatments in the Home Theater Installation and Systems forum; ceiling treatments I want to put some 2" OC703 panels on the ceiling but not sure where to mount the panels. Measuring ...
GIK Acoustics
Old 04-11-08, 07:15 AM   #1 (Link)
Alias: marcus
Loc: Houston, tx
User: #7534
Since: Mar 2007
udaman is offline
ceiling treatments
Measuring exactly at the tweeter, the L/C/R speakers are 3' from the front wall, 14' from the listening position, and distance between the L/R speakers are 9'. Ceiling height is 9'.
The tried the mirror trick but it's too hard with help from 7yr old. Placing the mirror against the ceiling and check if the speakers reflection can be seen from the listening position.
Any suggestions where and how to mount the ceiling panels? Or an easier way to identify the ceiling reflection points?
Old 04-11-08, 07:39 AM   #2 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Re: ceiling treatments
If the tweeters are at approx ear level, just measure straightline from seat to tweeter, go halfway along the measurement and then straight up.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 04-11-08, 07:52 AM   #3 (Link)
Alias: marcus
Loc: Houston, tx
User: #7534
Since: Mar 2007
udaman is offline
Thanks for the quick reply, Bryan.
If the speakers are "toed" in, I guess mount the ceiling panels following the same "toed" in angle.
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
HT acoustic treatments? charcoal grey Home Audio Acoustics 16 05-18-08 04:13 PM
readings after room treatments exojam REW Forum 7 06-01-07 09:02 PM
My DIY treatments exojam Home Audio Acoustics 19 05-25-07 03:33 PM
Pillows as Treatments MrPorterhouse Home Audio Acoustics 3 01-15-07 11:29 PM
Room Treatments spearmint Home Audio Acoustics 11 07-29-06 11:48 PM
Mach 5 Audio
