| Home Audio Acoustics 2 channel listening roomDiscuss 2 channel listening room in the Home Theater Installation and Systems forum; 2 channel listening room I recently converted a spare bedroom into a guestroom / 2 channel listening room. I have my equipment and furniture ... |
Views: 555 - Replies: 8
| 2 channel listening room I recently converted a spare bedroom into a guestroom / 2 channel listening room. I have my equipment and furniture in place. After reading through this forum I have learned that layout of the room is far from being adequate. Here is a pic of my current configuration. ![]() The entrance door and closet leaves no room for corner traps and the equipment rack and sub mess this up on the other two corners. The desk, bookcase, coffee table and ceiling fan mess up the first reflections. I am hoping to keep the desk and the bookcase in the equation and the coffee table and ceiling fan will probably go. Here's the deal. I work in the commercial real estate field and recently had a radio station relocate to a different property we own. They took everything with them but the acoustic panels on the walls. It looks like they were professionally installed. The panels do not have any markings to determine the type of insulation that was used. Here are a few pics of the panels that I hope can be used in my application above. ![]() ![]() ![]() If these are workable I am the DIY type so cutting them up and recovering or making the 1" panel thicker will not be a problem. Some more pics for a better visual of the room. ![]() ![]() ![]() ![]() Sorry for the long first post but thought it was necessary to evaluate properly. Much appreciation in advance for any help that can be given. Thanks | ||||
| | #2 | ||||
| Re: 2 channel listening room Do I notice some nice warm glowing bottles in that rack? Very niceThose panels are made of OC705 or equivalent I'm 99.99999% sure. They'll work fine in your application for a variety of things. If at all possible, I'd pull the speakers out to get them in front of the armoire. Gotta let those tubes do their single ended imaging magic! If you must sit so close to the wall, a min of a 2-3" panel or two behind your head will help control bass at the boundary. Make smaller panels for the folding closet door. Push the rack against the front wall to allow a panel on the left wall to do it's job of catching reflections and creating some symmetry. Bryan | ||||
| | #3 | ||||
| Re: 2 channel listening room Ecir38, First welcome I see its your first post! Second try to place sub on wall near speakers if possible so you can blend bass better, if nothing else make sure sub has phase switch as you may need to adjust. Place panels on wall behind you and at side walls to control first reflections and go from there. Also a blanket over anything between speakers will help sound big time. If you want any other ideas email me anytime and Good luck! | ||||
| | #4 | ||||||
| Re: 2 channel listening room Quote:
Thanks for recommendations, this should get me a good start and thanks for the compliments on the amp, it is a diytube set 300b hooked up to a Hagerman line and phono stage. Quote:
| | #8 | ||||
| Re: 2 channel listening room After doing more reading I decided that the desk should probably come out of the room. Here is the new layout I am thinking of. ![]() The panels will be the yellow things. I haven't built any of the panels yet. I have material coming for the panel behind the sofa and will put this one up first. The panels on the side walls are just a thought right now, how does this size and placement look? I have built a little smaller one of these that will be used in the ceiling corners since I don't have too many options for traps. http://www.realtraps.com/p_tri-corner.htm Any feedback on this or adding more treatment is welcomed, Thanks. | ||||
| | #9 | ||||
| Re: 2 channel listening room You're getting there. If you can get 4" or a gap behind the 3" behind your head that will help. I'd also see what you can do about building something 'chunk style' for the 2 front corners. While the tri-corner panels are good at dealing with all 3 room dimensions, they're simply not large enough and not thick enough to reach down into the bottom end well. Bryan | ||||
