sub behind the couch?? good or bad?!?! - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Discuss sub behind the couch?? good or bad?!?! in the Home Theater Installation and Systems forum; sub behind the couch?? good or bad?!?! i'll have my couch 'caty-cornered' in a corner of the room. the tv will be in the opposite corner. is ...
GIK Acoustics
Old 04-23-08, 01:01 AM   #1 (Link)
Alias: sollars
Loc: Kansas City, Missouri
User: #19719
Since: Apr 2008
mrsollars is online now
is it ok to place the sub directly beind the couch?...in that corner blocked in by the couch?
or better to place it behind the tv...in that corner?!?
thanks guys.
matt
Old 04-23-08, 02:22 AM   #2 (Link)
Alias: Maverick
Loc: Sandnes, Norway
User: #7168
Since: Mar 2007
atledreier is offline
Re: sub behind the couch?? good or bad?!?!
The clear and consise answer would be.. that depends.
I had my sub behind my couch, and loved it. In other rooms it didn't work at all, so.. try it!
My DIY build Status: Almost done.
My room thread
Old 04-23-08, 06:37 AM   #3 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
It might work. However, if you're sitting in a corner, bass absorption would be a MUCH better use of that corner. That way, you're taming the corner instead of exciting it.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 04-23-08, 09:03 AM   #4 (Link)
Alias: sollars
User: #19719
Since: Apr 2008
i understand about 'taming the corner'. however, i feel that behind the couch in this corner is the only ''allowable'' place for it to go. (see wife.)
on the plus side. the corner is one flat wall and one open railing that blocks off a descending staircase.
if this is the case....to i point the speaker towards the opening or towards the back of the couch?
thanks.
matt
Old 04-23-08, 09:16 AM   #5 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
mrsollars wrote: View Post
If that is the case then its not really a corner, you would be better off placing it in the other corner by the TV.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 04-23-08, 09:48 AM   #6 (Link)
Alias: sollars
User: #19719
Since: Apr 2008
i thought that it was best to have it off of one wall....or both if possible. the tv corner is blocked in with both walls...the couch corner is open on one side.
why is it that the tv corner is best?
thanks.
Old 04-23-08, 10:02 AM   #7 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
It's not. Corners give the most sheer output but also usually the lumpiest frequency response as they maximally excite all the room modes in all 3 dimensions. If there is a hidable place in the room, that isn't in a corner, that'd be better.
Bryan
Bryan Pape
GIK Acoustics
Old 04-23-08, 10:33 AM   #8 (Link)
Alias: sollars
User: #19719
Since: Apr 2008
i'm thinking there isn't a hideable place that isn't a corner.
the closest thing to a 'non corner' that's hideable is that 'corner behind the couch....that is open to the stairway.
is on the same wall as the tv good or bad? between the right or left front and the tv...
thanks.
matt
also. will an 'spl' meter make the better choice stick out like a sore thumb??
thanks
matt
Old 04-24-08, 06:27 AM   #9 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is offline
I you really have only that option, then you have no choice but to go for it.
Getting an SPL meter and hooking it up to REW is an easy way to place a sub. Position the sub, measure, move sub, measure. Which ever has the flatest response at the listening position, go with that.
Old 04-24-08, 10:18 AM   #10 (Link)
Alias: sollars
User: #19719
Since: Apr 2008
i plan on doing that...but i'm a mac user and i'm starting to notice there are a lot of problems between REW and mac. (from what i'm reading on here)
have there been more recent suggestions on getting good results between mac and REW?
also is there a recommendation for the ''cheapest, acceptable'' mic used for REW. i plan on purchasing an SPL meter and Avia disc from SVS when i order my speakers.....but i see many are recommending the digital spl for REW?
which setup should i with?
matt
Old 04-24-08, 02:24 PM   #11 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
matt
the Radio Shack SPL meter is what most of us use ... here is a link http://www.radioshack.com/product/in...entPage=search ... I think is the cheapest option for a microphone/meter combo.
Old 04-24-08, 02:28 PM   #12 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
The Shack meter will work fine for relative measurements - just don't count on it to be 100% accurate. If you apply the correction file for the meter, it's a lot closer.
Bryan
Bryan Pape
GIK Acoustics
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
Is this System good or bad? phill8890 Home Theater System Recommendations 4 02-19-08 11:15 PM
TC 1000 12" Sonosub - Good or Bad Idea wooferman DIY Subwoofers 4 01-30-08 01:30 PM
RL-p18 with a Linkwitz Transform... good, bad, or ugly? Owen Bartley SoundSplinter 57 11-17-07 08:21 PM
The Good, The Bad, and The Keystone!! Prof. Home Theater Projectors 12 06-16-07 08:42 PM
Good news for TiVo investors - bad news for Dish Network DVR users - UPDATE 2 HDBeat Home Theater, Audio and Video News 0 08-22-06 11:43 PM
Mach 5 Audio
