30 Hz absorber - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
30 Hz absorber
Discuss 30 Hz absorber in the Home Theater Installation and Systems forum; 30 Hz absorber Okay, I have a lot of details in my other thread (like pics, measurements, and what not). However, the scope ...
GIK Acoustics
Old 04-23-08, 11:33 AM   #1 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
30 Hz absorber
Okay, I have a lot of details in my other thread (like pics, measurements, and what not). However, the scope is probably a bit too broad. So I will break it down into specific questions that might generate more discussion.
The biggest problem I have is a 30 Hz wide band null in the room. This corresponds with the long length of the room (19') as a half wavelength.
So what appears to be happening is that the length of the room is creating a null wave because the "bounce" off the back wall is exactly out of phase with the incident wave.
So to prevent this, I have to absorb the max velocity of the wave to prevent or limit this reflection. (max velocity, min pressure and vice versa). I think I've got this right, let me know if otherwise.
So what's the best way to do this?
Old 04-23-08, 11:39 AM   #2 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Re: 30 Hz absorber
The null from a 19' dimension is going to be pretty low. You're better off dealing with it by not sitting in that null than trying to absorb it. Short of that, you'll likely have to build some sort of panel resonator as most standard 'soft' absorbtion isn't going to be terribly effective down that low - unless it's several feet thick.
It's not just about where you put it but also about getting enough of the wavelength in it to make much difference.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 04-23-08, 11:51 AM   #3 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Re: 30 Hz absorber
Hmm, I think I need to do a walk around the room with the mic (everything else being equal) and see which of these problems persist.
I didn't think I was sitting in the null (as I'm on an odd fraction of the room).
I'll take some more measurements.
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
Panel absorber and SPL detector Richard Daigle Home Audio Acoustics 4 11-08-06 02:31 PM
Mach 5 Audio
