Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Two subs, two good locations
Discuss Two subs, two good locations in the Home Theater Installation and Systems forum; Two subs, two good locations Hello! I have my two DIY LLT soundsplinters. I have one in each back corner now, and they are awesome ...
GIK Acoustics
Views: 435 - Replies: 6
Old 05-02-08, 06:15 AM   #1
Alias: Maverick
Loc: Sandnes, Norway
User: #7168
Since: Mar 2007
  atledreier is offline
Hello!
I have my two DIY LLT soundsplinters. I have one in each back corner now, and they are awesome there. I have a little dip between 20 and 40-ish Hz however. The dip is about 6-7dB.
If I have my subs up front between the screen and mains I have ruler flat from 13Hz up to 40ish, and a dip up to 70-ish.
Both positions play nicely from 60-70ish and up, and from 20-ish and down.
With the subs being DIY I have no individual phase adjustments for them. I was thinking if it would be feasible to have one sub in each location, or is this likely to fail? The two positions are about the same distance from the sweetspot. The subs are a pain to move so I am just asking if there's any chance of success or if there's no real chance this will work.
Old 05-02-08, 06:33 AM   #2
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Re: Two subs, two good locations
Only one way to find out - try it. You might get lucky and have everything fall into line. Might not. Have you tried them in the rear but not in the corners?
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 05-02-08, 06:46 AM   #3
Alias: Maverick
User: #7168
Since: Mar 2007
I have, as far as I can out of the corners. My surrounds are in the way forward, and the door to my study if I pull them toward the center. I might have to just try it, and see.... I was hoping for a 'no' though, cause moving tehm is a pain in the... Thanks, Bryan.
Old 05-02-08, 08:23 AM   #4
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
Sorry, I know it's a pain. Have you downloaded the newest version of REW that has the RTA functionality in it? That makes life a whole lot easier setting up subs.
Bryan
Bryan Pape
GIK Acoustics
Old 05-02-08, 09:19 AM   #5
Alias: Maverick
User: #7168
Since: Mar 2007
Yes I have. I'll play around with them this weekend. I have a baby that is a light sleeper, and running around in pink noise for hours isn't good for my mental health in the long run..
I'll kick the wife and kids out of the house and bring a mate over for beers and calibration. Too bad none of my friends are really into this whole setting up thing. They just want the couch to shake. That's the easy part...
How exactly would you go about setting this up using the new RTA feature? (or the old sweeps for that matter)
Old 05-02-08, 09:51 AM   #6
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
First thing I'd do is set a sub in your seating position and do the crawl around thing. Put the first sub where you find it best. Then bring in another sub and try to place it on the other side/other end of the room keeping the dimensions from boundaries different from the first one (unless you can set 1 dead center front and back). From there, set the first sub level. Then set the 2nd sub level to match.
Now, you play with the RTA moving the 2nd sub around until you get the best response smoothness.
This all assumes that you've gone through the whole procedure for the mains already and have them dialed in to produce the best response. Know what happens when you move your mains. If you have a hump or dip around the xover point, knowing how it induce the inverse from the mains with small movements will help blend things even better.
Bryan
Bryan Pape
GIK Acoustics
Old 05-02-08, 02:03 PM   #7
Alias: Maverick
User: #7168
Since: Mar 2007
I'll play around some tonight. Will post FR and waterfalls for you guys to comment on.
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
