Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater Installation | Systems > Home Audio Acoustics
  Discuss Don't know where to start in the Home Theater Installation | Systems forum; Don't know where to start I'm working on building my Theater Room. The room I am using is upstairs on the second floor of our ...
Views: 549 - Replies: 2
Old 05-06-08, 07:17 PM   #1
Alias: ivseenbetter
Loc: Yorktown, VA
User: #20380
Since: May 2008
  ivseenbetter is offline
I'm working on building my Theater Room. The room I am using is upstairs on the second floor of our house. I modeled it out the best I can using the google Sketchup program. If you want to look it is located here: http://sketchup.google.com/3dwarehouse/details?mid=271cb1378c716ad8e6ae3294e4529063
Anyway, if you don't want to look at it, the measurements are roughly 16' wide by 29' long with slightly less than 9' tall. It has a small offshoot from it on the side. I really keep reading how important room treatment is but I don't know where to begin. I keep hearing about having to use mics to calibrate and complicated programs to measure response curves (that I can't figure out how to read), and reflection points. Is there a "for dummies" guide to walk me through this? I want to address this and I want to learn "why" I would do this but I don't know where to begin.
Thanks
Chris
Old 05-07-08, 07:01 AM   #2
Shack Moderator
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
Re: Don't know where to start
An overhead floor plan, with proposed speaker locations would be helpful. The very generic advice is to cover as much of the front wall as possible with 2", i the side walls with 1-2" at the reflection points,2-4" spaced of the back wall for bass trapping, and superchunk bass traps in every corner you can. If your floor isn't covered, you need a rug, and 2" on the the ceiling should hurt either, especially if your center sits above your screen.
With that off-shoot, you'll want to maintain as much symmetry around your front as possible.
Oh...and where to begin is reading up on all the thread here in the acoustic forum. It will take a while, but will be very informative.
Old 05-07-08, 09:09 AM   #3
Shack Moderator
Alias: Bryan Pape
bpape's Avatar
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
On the rear wall, I generally like to use a reflective surface bonded to the absorbtion so it's still bass absorbtive but the surround field stays nice and lively. FSK or FRK works well in this application.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
« Home Theater Shack > Home Theater Installation | Systems > Home Audio Acoustics »
Bookmark and Share
Dish Network
