Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
MY DIY Panels
Discuss MY DIY Panels in the Home Theater Installation and Systems forum; MY DIY Panels I've had several panels of rigid fiberglass hanging around in my garage waiting to be turned into a form that ...
GIK Acoustics
Views: 1524 - Replies: 13
Old 05-14-08, 01:54 PM   #1
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
Loc: Bay Area, California
User: #53
  JCD is offline
MY DIY Panels
I've had several panels of rigid fiberglass hanging around in my garage waiting to be turned into a form that was generally more aesthetically appealing. This last week I finally purr-ty'd them up and thought I'd share the process in pics..
Step one -- Buy the rigid fiberglass
Owens Corning's OC703 is the most famous of the fiberglass panels, but there are several other manufacturers. My is actually produced by John Manville Corp. I think it cost me ~$8-$9/panel.
Step two -- Buy the "covering"
I've been told that a loose natural fiber works best. I ended up going with burlap and found some here that I was able to get in Red and Black for less than $2/yard. It looks like the prices have gone up a little, but it's still a great deal.
Step three -- Build a frame
As with just about all things, there is more than one way to skin a cat. There are some that will use some spray on glue and just glue the fabric directly to the fiberglass. This may be a cheaper alternative than the route I went -- except, I have a contractor friend who ripped some scrap wood for me to use in the frame. If I didn't have that free source, I'd probably have to spend ~$10/panel in wood for the frame. This is based on getting the cheapest wood strips at Home Depot in my area -- I think it's something like $0.59/ft x 16ft (4+2+4+2). You might want to use something a little more substantial if you think the panels might get bumped into a lot. For me, all I wanted was to staple the fabric to them. Here are some pics of the frame construction.
Cut the pieces into two 2' and two 4' lengths
Glue the ends
Staple the ends to secure during the glueing process
Final frame
Step four -- Cover with the fabric
Pretty simple, cut the fabric so that there is enough to cover the panel. Since these are going to be used in my garage and will always be hanging on the walls, I didn't care how the back of the panel looked, as can be seen in one of the pictures below. If these were going to be in the main house, I'd consider using some sort of thumb tack instead of staples. They'd be a little less intrusive than staples. I'd also make sure the entire back of the panel was covered. One other concern has to do with the fiberglass itself. There are some that have some health concerns related to the fiberglass, specifically, that breathing in the fiberglass can cause some problems. If this is a concern, then you should wrap the panel in something like polyester batting -- the stuff they use for quilts. And now for the pics..
Lay the panel on the frame
Cover with fabric to find the amount to use
Flip the whole thing to the back side
Fold over the fabric on the sides
Stretch the fabric and staple to the frame so that there aren't any wrinkles
Just stapling the fabric to the frame
Completed shot of back
Completed shot of front
In the end, my total cost per panel is probably about $13 and took about 2 hours to build six 2'x4' panels and two 2'x2' panels. Compared to what I'd have to pay commercially, it's a pretty good deal. They're not as polished as the commercial products and I don't get the support these companies provide, but they should function pretty similarly.
Anyway, there you go.
JCD
Old 05-14-08, 07:20 PM   #2
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: MY DIY Panels
Good job ...
Old 05-14-08, 07:39 PM   #3
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
Re: MY DIY Panels
That's Great JCD! You're giving us DIYers some ideas
ASME AI
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 05-14-08, 07:59 PM   #4
Shack Moderator
Alias: Prof.
Prof.'s Avatar
Loc: South of Adelaide
User: #3204
Since: Oct 2006
  Prof. is online now
Re: MY DIY Panels
Nice job JCD...Simple and effective..
I used the black burlap on my panels...Works a treat..
Prof..
Home Theatre...the never ending story!
Old 05-14-08, 08:06 PM   #5
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
User: #53
  JCD is offline
Re: MY DIY Panels
Simple is definitely the word of the day. I was so worried that it wouldn't work out well or I'd mess it up somehow I probably wasted a year before getting those guys built. Whole purpose of the thread was to show how easy it really is.
One more shot -- a couple leaning against the wall in my house
If I get a chance, I'll put the red and black next to each other. I've always liked the black/red combo.
One more comment -- another reason why I liked using staples, I can fix it should I later find a wrinkle or what to clean it up for whatever reason.
JCD
Old 05-14-08, 10:20 PM   #6
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is online now
Re: MY DIY Panels
Are they going to be placed at first and second reflection points, or somewhere else?
Prof..
Old 05-15-08, 04:12 AM   #7
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
User: #53
  JCD is offline
Re: MY DIY Panels
Prof. wrote: View Post
I'll probably try to hit the reflection points off the side walls, then the ceiling. Depending on the results, I may try to hit the back wall too. I doubt I'll be using these for bass traps. I would probably have to buy another 6 or 12 pack to do that.
JCD
Old 05-15-08, 08:11 PM   #8
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is online now
Re: MY DIY Panels
JCD wrote: View Post
JCD
If you're putting some on the back wall, then you will need the type of insulation that has the FSK facing..
I think Bryan also recommends that they should be 4" thick as well..
Prof..
Old 11-16-08, 04:10 AM   #9
Alias: dgshtav
Loc: SFO East Bay Area
User: #28625
Since: Nov 2008
  dgshtav is offline
Re: MY DIY Panels
Hi JCD,
Couple of questions:
1. Which JM Product did you buy?
2. Where in bay area did you buy it?
3. Am in SFO East Bay (Brentwood, Antioch, Walnut Creek Area)...do you know any JM dealers here?
Thanks,
DGS
Old 11-16-08, 01:58 PM   #10
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: MY DIY Panels
dgshtav wrote: View Post
Hi JCD,
If you're planning to do some acoustic panels ...you can use burlap, you can order it online from GIK acoustic (look for their link on the top of the page); or there's some other places online too.
If you want to use black fabric; I got some speaker cloth from Joann's Fabrics ... maybe their price is a little high ($10/yd) ... but if you want a different color ...burlap is the way to go.
Old 11-16-08, 02:07 PM   #11
Alias: dgshtav
User: #28625
Since: Nov 2008
  dgshtav is offline
Re: MY DIY Panels
salvasol wrote: View Post
I had Burlap (or even some drapery fabric) from a local fabric store not exceeding $3 per yeard.
Will check out GIK Acoustics as well.
I still need to know vendors the OP used to get the JM boards.
Old 11-16-08, 02:19 PM   #12
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: MY DIY Panels
... I thought you were asking about the fabric
I found this link from the first post ... maybe it can help you http://www.specjm.com/locator/default.asp ...
EDIT: GIK sells the 703 fiberglass boards ...
Old 11-17-08, 01:50 PM   #13
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
User: #53
  JCD is offline
Re: MY DIY Panels
Hi JCD,
Thanks,
DGS
1. I think it came from their Spin Glas line. They're all 2" thick, but I can't remember which densisty I ended up with.
2. Sorry, bought it online. I did some phone calls in the Bay Area, and it seems like I found some places in SF that I could buy it locally.. but, if I remember correctly, it was going to be more than I could buy it for online. Ebay usually has someone selling some sort of rigid fiberglass for a reasonable price. I've even seen them on craigslist occasionally. Another good buy would be from here.
3. Same as #2. I used that link and found these guys near Oakland -- www.macarthurco.com. They have it listed as rigid fiberglas on their website, but don't list a price. You'd have to call and find out (if you do, please report back with how much). The other option would be to contact all of the HVAC insulation guys in the phone book asking for rigid fiberglas or OC703. Someone will eventually know what you're asking for and be willing to sell a box of the stuff.
Good luck.
JCD
Old 11-19-08, 07:16 PM   #14
Alias: dgshtav
User: #28625
Since: Nov 2008
  dgshtav is offline
Re: MY DIY Panels
Am still waiting to hear back from a couple of people I spoke with.
Meantime, I have gone ahead and got the 9.5" thick R-30 pink stuff already. I think I will be able to compress it to 4" thick (thus increasing it's density) reasonable well to fit the frames.
Per Coeffs published by Bob Golds, the 9.5" thick batts are as good as OC 705. Am hoping that compressed they should hopefully do as well if not better (more so with the increased density).
I will know once I try a few panels.
Meantime, if anyone could give me some more leads here locally (SFO Bay Area), I would really appreciate it.
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
