Acoustic help in an asymmetrical living room - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Discuss Acoustic help in an asymmetrical living room in the Home Theater Installation and Systems forum; Acoustic help in an asymmetrical living room Hi Everyone! I am new to this forum, but love what I have been reading here! I look forward to ...
GIK Acoustics
Old 05-15-08, 02:34 AM   #1 (Link)
New Member
Alias: assagor
User: #20572
Since: May 2008
assagor is offline
Hi Everyone!
I am new to this forum, but love what I have been reading here! I look forward to everyone's opinions, insights, and assistance. I just moved into my new home and have some speakers on order. My floor plan is very open, and I know acoustics is going to be a problem I have attached some pictures that I think might help.
The first is the layout of the living room, and the adjacent entry, hallyway, and dining room. The TV and speakers are on the left wall that the sofa faces (highlighted in yellow in the 1st pic)
The second picture is a cgi image of what my living room wall (blue wall)looks like from the dining room.
The third picture is how my TV, speakers, subwoofer (far left) and media cabinet (far right) will be positioned on the blue wall.
I don't even know where to begin! Please help!
Trung
Old 05-15-08, 08:59 AM   #2 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is online now
Re: Acoustic help in an asymmetrical living room
Welcome!
If you can treat the left wall, then I'd recommend curtains on the window. If you can't, then I'd recommend some 2" wood horizontal blinds. We need to try to maintain some symmetry in the room.
If you don't already have a rack, a low, wide cabinet in front would be a better choice and leave the right corner available for some bass control.
The front wall should be pretty dead. 100% is preferable. If you can swing it, 2" would work best since things are a bit tight and we can't do a lot anywhere else due to the dining area, openings, etc.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 05-15-08, 03:16 PM   #3 (Link)
New Member
Alias: assagor
User: #20572
Since: May 2008
assagor is offline
Thanks Bryan! I plan on doing heavy curtains on the windows and maybe a 2" panel on the left wall. Would 24"x48"x4" panels be better on the front walls? Why is 2" sufficient?
I would've gone with a low console, but that center channel is a monster! 25.5" w x 12" h!
Would putting 2" panels on the back wall by the dining room help at all? Thanks.
Trung
Old 05-15-08, 07:53 PM   #4 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
... The front wall should be pretty dead. 100% is preferable. If you can swing it, 2" would work best since things are a bit tight and we can't do a lot anywhere else due to the dining area, openings, etc. Bryan ...
assagor wrote: View Post
... Would 24"x48"x4" panels be better on the front walls? Why is 2" sufficient?
What he mean is to cover the entire wall with 2" fiberglass panels , if you can do the 100% I think you can cover the most you can ... there's also 1", but Bryan is the expert here ... so, if he suggest at least 2" that's your best option
Old 05-15-08, 10:47 PM   #5 (Link)
New Member
Alias: assagor
User: #20572
Since: May 2008
assagor is offline
yikes! an entire wall of panels! Gotta check with the wife. Maybe I'll cover 50% of the wall.
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
Suggestions For Living Room? yourgrandma Video Displays and Processors 10 03-13-08 09:13 PM
PC Guy wants to meld PC fully into living room SpaceCowboy Welcome | Member Introduction 4 01-07-08 04:51 PM
My Stuff/Living Room jtmjnow Home Theater Gallery 1 08-22-07 02:35 PM
My living room/ht bonehead848 Home Theater Equipment 0 06-18-07 01:53 PM
My horrible living room niget2002 REW Forum 11 01-22-07 06:56 PM
Mach 5 Audio
