Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Where to get OC 703
Discuss Where to get OC 703 in the Home Theater Installation and Systems forum; Where to get OC 703 Just wondering where one would find 700 series product? Home Depot - Lowes? Or do I need to find a ...
GIK Acoustics
Views: 1826 - Replies: 19
Old 05-26-08, 12:07 PM   #1
Alias: KB
Loc: Maine
User: #21032
Since: May 2008
  kermyb123 is offline
Where to get OC 703
Just wondering where one would find 700 series product? Home Depot - Lowes? Or do I need to find a supply house?
Old 05-26-08, 12:33 PM   #2
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Re: Where to get OC 703
Look at either HVAC or metal building insulation supply houses. If you can't find it locally, PM me.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 05-26-08, 04:48 PM   #3
SRR
Alias: Tim
User: #20375
Since: May 2008
  SRR is offline
http://www.atsacoustics.com/cat--Fib...ards--106.html
I use the Rockboard 60, much cheaper. Search google for roxul rockboard 60 and you will be able to compare specs with the 705/703.
Old 05-26-08, 05:10 PM   #4
Alias: KB
Loc: Maine
User: #21032
Since: May 2008
Thanks for the tip... Anyone here ever work with both? Cheaper rearly means as good or better then....
Old 05-27-08, 10:11 AM   #5
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
SRR wrote: View Post
ATS is much more expensive than a local HVAC, and Rockboard is only good if you are framing it, as it is not as rigid as 703 or equivalent. Things to keep in mind.
I got 12 - 24x48x2" 703 shipped from EJ Davis about 1 year ago for $120. $220.68 from ATS.
Old 05-28-08, 11:41 PM   #6
SRR
Alias: Tim
User: #20375
Since: May 2008
  SRR is offline
Rockboard 60 is rigid, I should know I have 8 traps, unframed standing up, or leaning against the walls without frames.
Old 05-29-08, 01:34 AM   #7
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
No, you're right, I was thinking of Rock Wool. Still, 703 can be had for cheaper elsewhere.
Old 06-01-08, 12:07 PM   #8
SRR
Alias: Tim
User: #20375
Since: May 2008
  SRR is offline
Rockboard 60 is equal to 705, not 703. Seems to me the ATS price is very good.
Old 06-01-08, 01:22 PM   #9
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
Actually, though it's density is similar, it's acoustic properties are much different from 705 (better in the low end)
Bob Gold's Numbers:
All 2", OC noted on wall, Roxul not specified mounting
Hz. 125, 250, 500, 1000, 2000, 4000, NRC
OC703 0.17 0.86 1.14 1.07 1.02 0.98 1.00
OC705 0.16 0.71 1.02 1.01 0.99 0.99 0.95
RockBoard (RXL 60?) 0.32 0.81 1.06 1.02 0.99 1.04 0.95
I'd still call around to get some quotes, especially if you have a distributor locally. I've never ordered 705/RXL 60, but if ATS is twice the price on 703, then I would hazard a guess that there is $$ to be saved on their other products as well.
Has anyone out there bought or gotten quoted 705 or RXL 60 from a distributor such as EJ Davis?
Where to buy Roxul:
http://www.roxul.com/sw34444.asp
Old 06-06-08, 03:11 PM   #10
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
EJ Davis is currently quoting me $182 for eight pieces of 2x4 703 shipped to Colorado (that's $12 each for the 703 and $43 each for two shipping cartons). Marshall, do you know how you got to the $120 number for twelve pieces? A certain rep or something?
-- Otto
Old 06-06-08, 07:24 PM   #11
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
Well, I bought about a year and a half ago, so prices have certainly gone up. Ican't imagine they would have gone up that much, though. Maybe they figured out they were undercharging?
Susan Slater was who I dealt with at the time. You can also try Hamilton Something or other, here's my 18 month old quote from them...
Marshall, Thank you for visiting our site. OC 703 plain is in stock here in
Pittsburgh and your cost is .69 per sf. plus sales tax and frt. If you wish
to place an order please call Brian at 1 -800-233-3232 ext. 24 Thank You,
Doug
Old 06-06-08, 10:01 PM   #12
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
  Otto is offline
Hmmm. Thanks, Marshall. I'm also dealing with Susan. Maybe prices did go up, or perhaps it's shipping/gas. I'm also talking with Bryan, so we'll see what he comes up with.
-- Otto
Old 06-07-08, 08:08 AM   #13
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
They should come in boxes of 6, so is it the same price per if you order 12?
Old 06-07-08, 10:15 AM   #14
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
  Otto is offline
Not sure. It sounds like they were going to rebox them to four each. They did not advise that it might be better to buy two boxes of six. That's kinda what I'm looking at now with Bryan, and it looks like shipping is less for six than for four. Not sure why... I'm going to get something, though; I've waited long enough for room treatments.
-- Otto
Old 06-07-08, 10:24 AM   #15
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
More power to ya. I'm sure Bryan's helping you look at alternative like mineralwool and acoustic cotton?
Old 06-07-08, 11:10 AM   #16
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
Mineral wool is slightly less but I just personally hate working with it - ESPECIALLY if there's any kind of cutting going on. It just crumbles and makes a mess. 703 is MUCH easier to work with.
Cotton is great and actually performs slightly better in the bottom end but it's almost double the cost for the same density and thickness as 703 - even when discounted. The advantage of the cotton is that if you don't mind the look, you can get it in a variety of colors and just hang it plain without worrying about framing or covering it.
Overall, 703 is the bang for the buck, 'swiss army knife' for treatments.
Bryan
Bryan Pape
GIK Acoustics
Old 06-22-08, 04:28 PM   #17
Alias: Quenten
Loc: Tallahassee, Florida
User: #9895
Since: Jun 2007
  Tonto is offline
Acoustimac.com has 6 sheets of 2" 703 for $79.95. They did not give a shipping charge.
Old 06-23-08, 01:52 AM   #18
SRR
Alias: Tim
User: #20375
Since: May 2008
  SRR is offline
Can you fill me in why you would want 703 over RIGID rockboard 60? Which is more comparable to 705, which is way more expensive then 703.
It is cheap to my eyes from ATS, it has better bass response, it is easy to work with, why is 703 even in contention?
I give up.
Old 06-23-08, 07:14 AM   #19
Alias: KB
Loc: Maine
User: #21032
Since: May 2008
I have read that 703 offers lower fq bass properties....??
Old 06-23-08, 07:18 AM   #20
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
First of all, you don't need anything that dense for most applications. When putting up in thicker chunks, 703 - 3lb density will work just fine - sometimes better.
The other is simply ease of working with. I HATE working with mineral wool if I have to cut it. It crumbles at the drop of a hat where 703 cuts straight and easy like butter with a sharp knife. The mineral wool can hold together OK if you get the good stuff but most of it isn't any fun.
Also, that $80 isn't any great price for 703 and ATS is asking $86 for 6 pcs. I can get it for you for $69 all day long. So now, the Rockboard 60 is $60 and the 703 is $69.
Bryan
Bryan Pape
GIK Acoustics
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
