| Home Audio Acoustics Sub placement driving me crazy!Discuss Sub placement driving me crazy! in the Home Theater Installation and Systems forum; Sub placement driving me crazy! Simple way to find the best place for the sub, is to place the sub at listening position, play pink ... |
Views: 906 - Replies: 28
| | #26 | ||||
| Re: Sub placement driving me crazy! Simple way to find the best place for the sub, is to place the sub at listening position, play pink noise or even some bass heavy material, then go around the room and find where the bass is best, that is where to put the sub. Note; sometimes this dosnt work pefectly if there is no good place for the sub due to a bad room, but its a lot easier than moving the sub around and around forever. Nathan Funk Funky Waves Audio | ||||
| | #28 | ||||
| Re: Sub placement driving me crazy! There may be a solution. I had bad cancellation issues and found the only solution for me at the time was adding a second sub. I had to sit in line between them to get any decent bass response. See post #9 of this thread. (first pic.) http://www.hometheatershack.com/foru...y-theater.html If you could try this arrangement out, it may be what you need for your room. If you don't have a second sub, hopefully you can borrow one just for testing. | ||||
| | #29 | |||||
| Re: Sub placement driving me crazy! Hi Ahmed ... ![]() The idea was to move the seat out of the dead zone and seat between the four surrounds, but he said he owns a 7.1 already; so no need for parallel speakers ![]() P.S.: Quote:
