Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Effect of soffit in a HT
Discuss Effect of soffit in a HT in the Home Theater Installation and Systems forum; Effect of soffit in a HT Hi guys, I'm in the process (slow) of building a HT and am trying to plan the soffits. I'm tossing ...
GIK Acoustics
Views: 683 - Replies: 19
Old 09-08-08, 11:02 PM   #1
Alias: raZorTT
raZorTT's Avatar
User: #15619
Since: Jan 2008
  raZorTT is offline
Hi guys,
I'm tossing up whether to frame the soffits and then cover them with gyprock/sheetrock OR frame them and cover them with fabric.
Do you guys think it will affect the acoustics with the more solid construction?
I was thinking that if I go went down the fabric path I could potentially put small bass traps in the corner of the wall and ceiling
What do you guys think?
Cheers,
Simon
Old 09-09-08, 07:34 AM   #2
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Re: Effect of soffit in a HT
Hi Simon
Welcome to the forum. In either case, you'll want to build the soffiting AFTER the room is drywalled if you're going to use it for any kind of treatment, lighting/hvac without poking holes in the room, running cables, etc.
If you frame, fill with insulation, and cover with a thin layer of drywall, it will perform as minimally efficient bass absorber from about 50Hz to around 150hz. If you do just framing, insulation, and cloth, it will act more broadband and be a bit more efficient depending on the thickness and amount of surface area of the insulation.
Which way to go? Really depends on what's happening in the rest of the room and how the rest of the acoustical map looks.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 09-09-08, 10:59 PM   #3
Alias: raZorTT
raZorTT's Avatar
User: #15619
Since: Jan 2008
  raZorTT is offline
Thanks for the welcome Bryan
I guess I need to go into a bit more detail sorry about that. Hopefully this isn't going to be too long!
The room dimensions are 4.7m (15.4ft) wide, 6.0m (19.6ft) long and 3.0m (9.8ft) high. Even though the room is going to be my HT I had to compromise and put in 4 thin and tall (~500mm\20inch wide, 2m\6.5ft high) windows on one side.
All of the walls have insulation inside and I have used a thicker gyprock/drywall. Not quite room in a room or green glue but that was all I could do unfortunately. The room has been drywalled and plastered.
For other treatments I was planning to cover the wall behind the screen (building the screen off the theater wall) and up to the L & R speakers on the side walls from floor to ceiling. We don't have linacoustic here in Australia so I have been trying to find something equivalent. So far i'm probably looking at 50mm/2inch thick CSR supertel http://www.bradfordinsulation.com.au.../Supertel.aspx
Along the sidewalls i'd also like to cover up to ear level, but am not sure how the windows will affect things. Do you think it would be better to cover the one wall completely and on the other side, cover the bits that aren't windows? Or would it be better to mirror the coverage of the window side on the complete wall?
Will some thick curtains, to handle light transmission, help with any absorption? or not really?
I was planning on putting bass traps (Superchunk? the triangle pieces stacked up) in the corners of the screen and side walls
With that essay out of the way, back to the soffit. I am planning to put downlights in the soffit along the sides walls, the rear wall and some above the screen. Also i'm going to put in a light tray for a rope light. I'm not really for or against a particular construction, just if one has benefits then i'd like to go down that path.
Thanks for making it this far. I'd really appreciate your thoughts.
Cheers,
Simon
Old 09-09-08, 11:09 PM   #4
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
Curtains can help for general reflections if they're relatively thick (and will need to be for good light control) and are made of an absorbant material. You want to keep symmetry left to right in front of you. You could likley get away with mixing it with curtains on the one side. I'd likely use 1" on the side walls.
With that particular setup, I'd probably shoot for the rear soffit to be pretty much just frame and absorption covered in cloth. Sides can be drywall filled with insulation.
Bryan
Bryan Pape
GIK Acoustics
Old 09-10-08, 10:11 AM   #5
Alias: raZorTT
raZorTT's Avatar
User: #15619
Since: Jan 2008
  raZorTT is offline
Thanks Bryan,
Ok so I'll aim to do something along the lines of the attached image. the red is 2" thick and the green 1" thick.
Cheers,
Simon
Old 09-10-08, 10:26 AM   #6
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
Don't forget the chunk style absorbers in the front corners. I'd also probably go ahead and make the left wall solid instead of strips to better match the other side with the curtains.
Also, the last 2 panels on the sides in the rear, I'd face those with something like FSK to add a little more midbass control back there and keep it from getting too dead in the highs.
Bryan
Bryan Pape
GIK Acoustics
Old 09-10-08, 04:03 PM   #7
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Here is another idea for Blocking a window ... this helped the Prof. with light control and accoustics
Old 09-11-08, 12:26 AM   #8
Alias: raZorTT
raZorTT's Avatar
User: #15619
Since: Jan 2008
  raZorTT is offline
bpape wrote: View Post
Bryan
Is FSK the perforated paper that is sometimes on the back of the insulation? So have it facing into the room instead of against the wall??
Cheers,
Simon
Old 09-11-08, 12:43 AM   #9
Alias: raZorTT
raZorTT's Avatar
User: #15619
Since: Jan 2008
  raZorTT is offline
salvasol wrote: View Post
HMMMM.. now you've got me thinking
That would be the best solution. I wonder if I can get approval to plug them up .
I had always wanted to bulid fabric frame panels to put on the walls, but had kind of given up on the idea due to needing to put in curtains to block out the windows.
Would the best thing to do be to make a plug that is like a wall? so attach insulation to gyprock/sheetrock, and then have a fabric panel with 1" thick absorption material over the top? Or would I be better off with the 1" thick strips on the wall like in the above image and plugging the windows like Prof. ?
Probably the first option?
Cheers,
Simon
Old 09-11-08, 07:22 AM   #10
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
Either can work just fine. If you build a plug, make sure it's filled with insulation to damp the cavity you're forming or it will resonate.
FSK is a little heavier than what you're thinking, It's like a heavy kraft paper on one side, a foil on the other, and a fiber mesh in the middle. You'll see it sometimes already bonded to things like pipe insulation.
Bryan
Bryan Pape
GIK Acoustics
Old 09-11-08, 09:00 AM   #11
Alias: raZorTT
raZorTT's Avatar
User: #15619
Since: Jan 2008
  raZorTT is offline
Thanks guys!!
This is sort of off topic, but how do people measure the effect of treatments in their room?
Is it fairly specific equiptment? or is there a DIY piece of equiptment that people can get their hands on?
Cheers,
Simon
Old 09-11-08, 09:46 AM   #12
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
If you have something like a Radio Shack SPL meter, you can download Room EQ Wizard here on this site (free download) and run it on a PC tied to your system. You'll need a bi-directional sound card (capable of record and playback simultaneously) also.
Just remember when measuring, that you're interested not only in frequency response, but also impulse response and decay times.
Bryan
Bryan Pape
GIK Acoustics
Old 09-12-08, 07:20 PM   #13
Alias: raZorTT
raZorTT's Avatar
User: #15619
Since: Jan 2008
  raZorTT is offline
thanks Bryan I'll check out the local electronics stores
Old 09-12-08, 08:35 PM   #14
Shack Moderator
Alias: Prof.
Prof.'s Avatar
Loc: South of Adelaide
User: #3204
Since: Oct 2006
  Prof. is offline
Hi Simon,
I've been off line for a few days, so I'm just catching up..
I used the Supertel insulation in my theatre for acoustic panels and bass traps and it works well..
Bradfords have a BPF Supertel (black paper face)..which I think is similar to the FSK.. that I used for the rear window plug..
The window plug has 4 inch thick Supertel fitted..one 2 inch panel of plain Supertel and one 2" thick panel of BPF Supertel..
Also you can get an SPL meter for Dick Smiths fairly cheaply..
EDIT..I should also mention that you only need to use the faced Supertel for any panel on the rear wall..nowhere else..
Prof..
Home Theatre...the never ending story!
Old 09-21-08, 07:08 AM   #15
Alias: raZorTT
raZorTT's Avatar
User: #15619
Since: Jan 2008
  raZorTT is offline
Sorry Prof.
Have been sick over the past week..
Where did you source the supertel from? a hardware store or someone more specialised?
Cheers,
Simon
Old 05-09-09, 04:11 AM   #16
Alias: raZorTT
raZorTT's Avatar
User: #15619
Since: Jan 2008
  raZorTT is offline
Hi Simon
Bryan
Hi Bryan,
I was looking to get an idea of what is happening in the room before I start framing the soffits etc. I've gotten the radio shack SPL meter and the SB live external to hook everything up.
I've gone through the REW help file and don't think i'll have any issues calibrating everything. However,
I haven't been able to find a guide on what things I need to test? Is it as simple as using the measurement button and picking a bunch of different frequencies? Do I need to just test the sub by itself? or Include the mains? Should the center and surrounds be part of it as well?
Have you seen in your travels a post or guide that steps beginners though?
Cheers,
Simon
Old 05-09-09, 10:01 AM   #17
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
Hey Simon
There are some pretty good tutorials here on the Shack.
You'll just run a sweep. You can then have it generate impulse response, frequency response, and decay time/waterfalls. There is also the RTA function that's very helpful in tweaking sub/seating locations.
Bryan
Bryan Pape
GIK Acoustics
Old 05-09-09, 10:15 AM   #18
Alias: raZorTT
raZorTT's Avatar
User: #15619
Since: Jan 2008
  raZorTT is offline
Thanks Bryan,
So should I just use the mains and sub? or hook the center and surround speakers up aswell?
Cheers,
Simon
Old 05-09-09, 10:30 AM   #19
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
You'll want to take several measurements. Obviously the one that matters most is the mains and sub.
You'll want one with just the sub so you can work on positioning. 1 with just mains running full range so we can see where there may be overlap around the xover frequency, and 1 with all 3.
Bryan
Bryan Pape
GIK Acoustics
Old 05-10-09, 11:11 PM   #20
Alias: raZorTT
raZorTT's Avatar
User: #15619
Since: Jan 2008
  raZorTT is offline
Thanks Bryan!
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
acoustics, soffit
