EQ Question - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 16 Old 08-02-16, 11:30 AM Thread Starter
Matthijs
EQ Question
It surely has bin asked before but i coudn't find it in the search options.
My question is about when and if to eq ?
i have read this nice tutorial from some years ago
http://www.hometheatershack.com/foru...urve-long.html
but its only meant for bass. I was wondering if this has to do with something ?
is it more safely to eq the bass for a better response then to eq above it ?
Or does it equaly creates the same benefits and concequences ?
I have read allot of diffrent stories about it so im realy curious in
what the facts are. Also where to draw the line between eq adjustments or treating the room?.
matthijs87 is offline
post #2 of 16 Old 08-02-16, 11:37 AM
tonyvdb's Avatar
Tony
Re: EQ Question
EQ to the lower end is much less invasive on the over all imaging of the soundtrack. Applying EQ above 400Hz has to be done with care and generally its not a great idea to boost. When applying EQ above those frequencies it must be done evenly on both channels otherwise imaging can be dramatically effected in a bad way.
Often room Acoustics play a larger role in how it sounds and should be addressed first.
Home theater:
Living room system:
tonyvdb is online now
post #3 of 16 Old 08-02-16, 12:53 PM Thread Starter
Matthijs
Re: EQ Question
Ah yes that makes totaly sense, thank you !.
When aplying EQ above the 400 would you say the stereo imaging is the only important thing to look out for ?
post #4 of 16 Old 08-02-16, 12:56 PM
tonyvdb's Avatar
Tony
Re: EQ Question
Yes, but keep in mind that when you change the imaging its not just the stereo image that can be affected. Phase is also changed.
Home theater:
Living room system:
post #5 of 16 Old 08-02-16, 05:17 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: EQ Question
What Tony said down the line, and I’ll add I haven’t had any issues boosting above 400 Hz. Just use matching filters, and you have to use EQ judiciously on the main speakers. You can’t use any crazy boosting or cutting because the main-channel amplifiers have much less power than the typical subwoofer and as such can run out of headroom real fast.
Here’s a good thread on full-range EQ you might want to digest. Feel free to ignore most of the advice given by the party making the second post.
Spridle’s Experiment
Treatment mainly affects reflections in the room, and typically has minimal effect on speaker’s frequency response. Here’s a good post on the topic.
Equalization vs. Treatments
post #6 of 16 Old 08-03-16, 07:01 AM Thread Starter
Matthijs
Re: EQ Question
Verry great stuff ! this realy helps allot .
@ tonyvdb : isn't phase the only thing responsible for diffrent stereo imaging in this case ? and thus the same thing, or better said the source for the diffrent stereo image ? What i learned is that the stereo image can only be changed by diffrent (left and right)frequenties and or diffrent timings in a nutshell. thus the phase and stereo imaging are the same things for "this" example becouse the timing wont be affected when eqing, is that true ? or am i missing something ?
@ Wayne A.
Thank you ! I will read all of it . but when talking about crazy boosting or cutting, where would you say the danger zone starts approximately ?
post #7 of 16 Old 08-03-16, 08:08 AM
Re: EQ Question
Impossible to say. It all depends on available amplifier power and the efficiency of the speakers, which is different in every system. Fortunately with main-channel speakers it’s not hard to tell when you’ve gone over the line, as you’ll hear audible distortion at the stressed frequency when you run out of headroom.
Wayne A. Pflughaupt
post #8 of 16 Old 08-05-16, 11:38 AM Thread Starter
Matthijs
Re: EQ Question
Okay thanks,
Is there an option in REW to edit both left and right speakers at the same time ? At the EQ Menu i can only get a prediction of one file. For the matching filters it would realy come in handy to look how it affects both. I have searched for it but cant figgure it out.
post #9 of 16 Old 08-05-16, 12:27 PM
tonyvdb's Avatar
Tony
Re: EQ Question
matthijs87 wrote: View Post
Yes and no, there is not hard fast answer to this question as there are so many variables at play as speaker position can also play a part in the outcome.
Home theater:
Living room system:
post #10 of 16 Old 08-06-16, 02:09 AM
HTS Moderator
Reviewer
AudiocRaver's Avatar
Wayne Myers
Re: EQ Question
Although in theory what you are saying is correct, it seems more accurate to think in terms of timing than phase, to me at least. Looking at typical phase plots between two channels does not give a clear idea at all what might be happening with imaging, but looking at impulse timing plots can be very informative.
AudiocRaver is offline
eq , question
