| | 01-04-09, 01:38 PM
#1 | | | Help with acoustics I have a room 30'x15' w/ 8' ceilings. Harmon Kardon AVR 254 with 7.1 set up.
What are your recommendations on improving the audio charateristics of the room? Currently a "boomy" room, especially with Dolby TrueHD/DTS HD action movies. Louds are LOUD!!! Would like to "absorb" some sound without making the movie dialouge disapear.
Just starting to make this into a home theatre/office so any suggestions welcomed. Below is a diagram of the room. Thanx.  | | | Advertisement | | | | | 01-04-09, 02:15 PM
#2 | | Shack Moderator Bryan Pape | | Since: Sep 2006 Wildwood, MO (St. Louis) My Photos |
| | | | Re: Help with acoustics Hi Tim
The best thing you could do is turn things 90 degrees to face the left wall of the room. That will give you a lot more space behind the seating which is critical. Sitting with the seating right up against a wall will put you in a place where the bass will always build up.
After that, you'll want to treat the front wall, the front corners heavily, and reflections on the side walls. The area rug between you and the speakers is a very good idea.
Bryan
Bryan Pape
Lead Acoustical Designer GIK Acoustics | | | 01-04-09, 03:04 PM
#3 | | | Re: Help with acoustics First of all thank you for a VERY speedy response. That was my first idea, to move everything to take advantage of the length of the room. Here are the problems with that...
Sofa is so large (terrible problem right  ), that I would have to put it directly up against what would then be the left wall, otherwise there is no way to get around it. Then...where do you put the left surround speakers? Unless I put them on sofa tables directly behind the sofa (see diagram below).
How would that effect the spatialness/direction of the sound?
Thanks again.  | | | 01-04-09, 03:09 PM
#4 | | Shack Moderator Bryan Pape | | Since: Sep 2006 Wildwood, MO (St. Louis) My Photos |
| | | | Re: Help with acoustics Well, yes, that's a problem when seating is too large for the room. Realistically, pretty much any L shaped seating like that is not going to be optimal but it is what it is. At least your main seating will be much better.
Mount the side surrounds to the sides of the main seating area. Mount the rear surrounds from the ceiling behind the seating. In the old arrangement, you wouldn't get decent surround anyway as the seating was at the rear boundary. At least some of the seats this way will have good surround field and bass response.
Bryan
Bryan
Bryan Pape
Lead Acoustical Designer GIK Acoustics | | | 01-04-09, 05:26 PM
#5 | | Shack Moderator Prof. | | Since: Oct 2006 South of Adelaide My Photos |
| | | | Re: Help with acoustics In your first configuration where the depth of the theatre area is 15', I wouldn't even consider using a 7.1 system..
As you have shown it, your LS, LBS, RBS, and RS are all on the same plane..That's not going to work..
With that design your only alternatives are to move the side surrounds further forward, either on stands or ceiling mounted..Forget about the back surrounds, they won't add very much to the overall surriund sound field..
The 90 degree orientation is the better alternative..
Is the sofa a modular unit? Prof..
Home Theatre...the never ending story! | | | 01-04-09, 05:54 PM
#6 | | | Re: Help with acoustics It is a modular unit, in three pieces. I'm tryint to come up with a way to split the couch into pieces, while still allowing for "Couch Potatos" to enjoy watching TV/Movies. This is the MAIN TV watching area in the home as well as movie watching.
And I only put the back speakers into the mix, because I had some small speakers sitting in the closet. Of course could live without those if necessary. | | | 01-04-09, 08:26 PM
#7 | | Shack Moderator Prof. | | Since: Oct 2006 South of Adelaide My Photos |
| | | | Re: Help with acoustics Quote: tmmths wrote:
It is a modular unit, in three pieces. I'm tryint to come up with a way to split the couch into pieces, while still allowing for "Couch Potatos" to enjoy watching TV/Movies. This is the MAIN TV watching area in the home as well as movie watching. | Do you have just a TV in that room, or are you planning on putting in a projector as well? Prof..
Home Theatre...the never ending story! | | | 01-04-09, 09:47 PM
#8 | | | Re: Help with acoustics Just the TV. Samsung HL61A750 61" DLP. | | | 01-05-09, 03:53 PM
#9 | | Shack Moderator Prof. | | Since: Oct 2006 South of Adelaide My Photos |
Just the TV. Samsung HL61A750 61" DLP. | In which case, I would just leave it the way you originally showed on the plan, and just move your L&R surrounds further forward and forget the back surrounds..
Also, move your sofa further forward away from the back wall..
For TV viewing it should be fine.. Prof..
Home Theatre...the never ending story! | | | 01-05-09, 03:59 PM
#10 | | Elite Shackster Platinum Supporter David | | Since: Oct 2006 Fontana, CA My Photos |
For TV viewing it should be fine.. | What about just leaving the left + right surround speakers on the back wall, and remove the other two and moving the couch a little (1'-2')to the front???
EDIT: He can point them to the seating position ...
Reason: Add text
