Audio General, Inc.: Great deals on projectors, screens and electronics. Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Power Sound Audio designs, develops, and assembles high quality loudspeakers and subwoofers for home theater environments. Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! OPPO Digital - Universal Network 3D Blu-ray Players - Buy Direct from the Manufacturer KEN KREISEL Sound & Design Genelec: Active Speakers and Speaker Systems Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices RAM Electronics: Audio, Video, Home Theater and Computer Cables. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Check out the Woot product for today! Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! DIY Parts and Accessories as well as custom built cables. Fast worldwide shipping. Madisound Marantz Value Electronics: A trusted retailer and custom installer that specializes in whole-house audio, home theater, Plasma, LCD, LED, HDTVs, Blu-ray and more. Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! SVSound GR Research - Offering audiophile quality loudspeakerkits, high quality crossover components, drivers and accessories. Also providing a wide range of design services from complete commercial product line design to assistance with individual custom products and upgrades.
Home Rules Register Gallery Glossary FAQ
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater Installation | Systems > Home Audio Acoustics
Donations Reviews Vendors
GIK Acoustics
Views: 2452 - Replies: 8
Old 02-05-09, 06:44 AM   #1
chas
Since: Jan 2007
Minnesota
  chas is offline
I started this thread.
Rear surround placement
I have a fairly large room (about 40 X 14) but I only use about a 14 X 16 area for the TV/sound system. The room has 8 foot ceilings. If I ceiling-mount rear surrounds (using Omni 20 ceiling mounts), how far back should they be from the seating area...and should they be angled down? Use for these would be mainly TV and movies as I usually listen to music in 2 channel.
Here's a link to a sketch of the layout:
http://swbg1.tripod.com/1355_famrm_300_half.jpg
And a photo looking forward from where the rear surrounds will go:
Thanks.
Old 02-05-09, 06:53 AM   #2
jason
Since: Jan 2007
Australia
  cinema mad is offline
Re: rear surround placement
I would Say you would want the rear surround speakers no closer than 2' to 3' from the rear seat...
If you have A look on the DTS or Dolby web sites they have all the info there...
Cheers....
Old 02-05-09, 09:30 AM   #3
tonyvdb's Avatar
Tony
Since: Sep 2007
Edmonton, Alberta, Canada
My Photo Gallery
  tonyvdb is online now
Are you doing a 5.1 or 7.1 speaker setup?
If 5.1 the rear speakers can be placed on either the side walls or the rear walls (your choice) if placing on the side walls you want them to be directly beside where you sit on either side of the room.
If you place them on the rear walls then they need to be at least 4' apart and like Jason said at least 2' behind where you sit.
Home theater:
EV Sentry 500 monitors, 4 Mission 762i's Surrounds, Klipsch RC-52 Centre, SVS PB13U sub, Panasonic BDT220, Harmony 1100, Nintendo Wii
Panasonic PT-AE4000 on a 120" 2,35:1 fixed screen
Living room system:
Panasonic TC-P50ST60, HD-PVR & WDTV Live, Harmony 1000
Old 02-05-09, 10:28 AM   #4
chas
Since: Jan 2007
Minnesota
  chas is offline
Sorry...this is for the rear surrounds in a 7.1 (already have been running 5.1).
Since they will be ceiling mounted and there is plenty of space behind the seating going 2-3 feet back is no problem. Wasn't sure if I should go any further back than that...or if they should angle down towards the seating. It seems that letting them fire straight ahead would cause reflections off the front wall.
Old 02-05-09, 10:38 AM   #5
tonyvdb's Avatar
Tony
Since: Sep 2007
My Photo Gallery
chas wrote: View Post
You want them to fire somewhat at the listening area but not directly at your ears.
Home theater:
Living room system:
Old 02-06-09, 10:11 AM   #6
Banned!
Marshall
Since: Sep 2006
Monmouth, OR
My Photo Gallery
  eugovector is offline
Re: Rear surround placement
I shoot mine just over my head, and criss-crossed (left rear firing towards the right of the seating position, right rear, firing towards the left). I find this helps to produce the most diffused sound from my monopoles.
In the end, I'd say mount them where they look good and make the most sense (2-3' is good) and then play around with the angles. Jim from Platinum Audio says there's nothing wrong with "splashing them around a little"
(We recorded a session on placement not too long ago. I'll have that episode of the Podcast out this weekend).
Old 02-11-09, 12:05 AM   #7
Jim
Wetumpka
  JimP is offline
May I suggest that you position your rear surrounds so that they're 4' apart and the same distance to the primary listening position as the side surrounds are. This should give you better phantom speaker positions. As far as aim is concerned, this is going to depend on the characteristics of your particular speakers. I've seen some that do better aimed at the primary listening position and others that did better aimed forward in terms of having a broader sounds stage.
You're sub position caught my attention. Which sub is that??
Old 02-11-09, 05:56 AM   #8
chas
Since: Jan 2007
Minnesota
  chas is offline
JimP wrote: View Post
Thanks for the suggestions Jim. The sub is an SVS PB12-NSD/2.
Old 02-11-09, 09:41 AM   #9
chas
Since: Jan 2007
Minnesota
  chas is offline
This sounds logical to me....thanks again.
 Reply     Post New Thread     Back to Top of Page
« Home Theater Shack > Home Theater Installation | Systems > Home Audio Acoustics »
placement, rear, surround
Bookmark and Share
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2013, Home Theater Shack, LLC.
OUR SPONSORS
Accessories4less
Audio General Inc
Chase Home Theater
Discount-Merchant
Emotiva
Epik Subwoofers
Exteris Audio
Genelec
GIK Acoustics
GR Research
HTD: Home Theater Direct
KEN KREISEL
Madisound
Marantz
MiniDSP
OPPO Digital
Power Sound Audio
RAM Electronics
Stereo Integrity
SVSound
Take Five Audio
The Audio Insider
Value Electronics
Visual Apex
The Sub Zone
OUR AFFILIATES
Abe's of Maine
Boston Acoustics A Series Speakers
Cables.com
Denon - Buy Direct. Free Shipping.
Electronics Express
Fluance
GamersGate
Harman
J&R.com
Shop for Harmony Remotes at Logitech
Shop MCM Electronics for Your Home Theater Needs
Musician's Friend Stupid Deal of the Day
Once You Know, You Newegg
Overstock.com
Parts Express: Your #1 Speaker Building Resource
Roku + Netflix = Instant Movies on your TV
Solid Signal Antenna Superstore
Sonos Wireless Music Player
SquareTrade Warranties
Vann's
vudu.com
Woot!
Zzounds
Abt Electronics
Best Buy
Butterfly Photo
Circuit City
DIRECTV
emusic.com
GameFly
HDtracks High Resolution Music Downloads
HP Computers
Klipsch
MarvelStore.com
Monoprice.com! Best quality products at the lowest price, Always!
Instantly watch from thousands of TV episodes & movies streaming from Netflix. Try Netflix for FREE!
OneCall
Buy Televisions at Panasonic.com
Paul's TV
SMS Audio
503327_Get Free Shipping At Sonic Electronix!
Sony
Super Media Store!
Velodyne
Official Shop of Warner Bros
World Wide Stereo
Epic 80 Home Theater Speakers
Search Engine Friendly URLs by vBSEO
