| Home Audio Acoustics What frequencies peaks and dips aren't significant?Discuss What frequencies peaks and dips aren't significant? in the Home Theater Installation and Systems forum; What frequencies peaks and dips aren't significant? I've read post from time to time where someone would post a REW graph with a pretty large dip or ... |
Views: 380 - Replies: 4
| What frequencies peaks and dips aren't significant? I've read post from time to time where someone would post a REW graph with a pretty large dip or peak and comment that they don't seem to hear it. The response was that it apparantly wasn't at a fundamental. My question is what are these frequencies? | ||||
| | #2 | ||||
| Re: What frequencies peaks and dips aren't significant? There are many other factors that can be mistaken for having to do with the rooms dips or peaks. There are dynamics, noise, phase, timing, distortion, impedence, crossovers, filters, and the list goes on. There are many other things that contribute to percieved flat response before the signal even reaches the speaker, then leaves into the room. It could also be that they don't have broadband absorption and they percieve only those sounds that arrive at the listening position that are even in decay, and everything else is just the room's resonance which might seem to add a reverberation effect rather than hearing some kind of note. | ||||
| | #3 | |||||
| Re: What frequencies peaks and dips aren't significant? Quote:
The other thing is that those variations in response are very likely audible when energized, but they don't bother the listener in question, and our hearing's ability to adapt is remarkable, so there is a good possibility that if given the opportunity to compare with and with out the peak/dip it may be found more objectionable. Our calculations are always correct, for we are gigantic brains. | |||||
| | #4 | |||||
I have read a number of times that if a peak or dip is very narrow, it is less likely to be noticed. | |||||
| | #5 | ||||
| Re: What frequencies peaks and dips aren't significant? I wonder if they mean fundamental frequencies involving Intermodulation or the length of the sound wave. Pink Noise can reveal dips or peaks in a room. According to the Master Handbook of Acoustics so does classical music. ![]() | ||||
| Bookmarks |
| Tags |
| aren't, dips, frequencies, peaks, significant? |
| Thread Tools | |
