Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Where to buy near Saskatchewan
Discuss Where to buy near Saskatchewan in the Home Theater Installation and Systems forum; Where to buy near Saskatchewan I found a source of linacoustic in Saskatoon, but they only sell 200 sq foot amounts or more. I also ...
GIK Acoustics
Views: 306 - Replies: 8
Old 03-06-09, 04:49 PM   #1
Alias: greg
Loc: Saskatchewan Canada
User: #34503
Since: Feb 2009
  gobrigavitch is offline
I found a source of linacoustic in Saskatoon, but they only sell 200 sq foot amounts or more. I also see that it is rated at only 1.5lbs which is only half as dense as OC 703 if I'm understanding correctly. I wonder if anybody knows where to buy materials in Saskatchewan. I'm looking for stuff to make flat traps, chunk traps and to cover front wall of the theater.
Any help is greatly appreciated
Old 03-06-09, 04:53 PM   #2
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Re: Where to buy near Saskatchewan
That's one of the issues with Linacoustic is that it comes in rolls no matter what you actually need. 1.5 lb in that application for reflections will be fine.
Most likely in Canada, you'll want to check out mineral wool suppliers.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 03-06-09, 05:20 PM   #3
Alias: greg
User: #34503
Since: Feb 2009
Thank you
Would that mean Roxul type products. Any good ideas on where to start looking. I'll try the Roxul website and go from there for now.
Old 03-06-09, 05:55 PM   #4
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
Home Depot carries Roxul products according to their website.
We're all in this together!
Members DIY Subwoofer Database
Old 03-06-09, 08:56 PM   #5
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
Roxul is great if you can get it. There are a few others that I can't remember right now. I'll try to get my brain engaged and post back later.
Bryan
Bryan Pape
GIK Acoustics
Old 03-06-09, 09:26 PM   #6
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is online now
Mike P. wrote: View Post
Yes, The Home depot has it in Canada. however they sell out fast and are often out of the smaller stuff.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 03-07-09, 12:26 AM   #7
Alias: Fred
User: #20762
Since: May 2008
  fredk is online now
For fiberboard, try Ottawa fibre to see if there is a dealer near you. They used to list their dealers, but it looks like you need to give them a call now.
Old 03-09-09, 11:29 AM   #8
Alias: greg
User: #34503
Since: Feb 2009
Thank you all for all the help. Looks like I'll give Home Depot a try. I'm in no rush, so if they don't stock what I'm after then I can likely get them to order it in.
Old 03-09-09, 11:36 AM   #9
Alias: greg
User: #34503
Since: Feb 2009
I thought of another question with regard to Linacoustic.
I was going to get the 2 inch thickness to use on the front wall. Is it better to put it right against the wall or whould I put 2x2 strips behind it to bring it out from the wall a bit to improve the absorption.
If I buy a roll I'll have more then enough for the front wall. Can I use it to make 2x4 foot panels for the side walls? Would I be giving up much compared to similar panels out of Roxul products?
I guess I'm trying to figure out whether I'd be better off to buy a roll of Linacoustic and use it for the front wall and for a few side panels or to just buy Roxul sheets? I'm guessing the Linacoustic is significantly less expensive and that's why people use it in home theaters. If it costs considerably less will I be giving up much in performance? If it costs the same, then I suspect it's better to go for Roxul sheets.
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
saskatchewan
