Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
acoustical plan - suggestions wanted
Discuss acoustical plan - suggestions wanted in the Home Theater Installation and Systems forum; acoustical plan - suggestions wanted I have a plan, I just don't know if it is a good one. Most of my decisions were based ...
GIK Acoustics
Views: 369 - Replies: 3
Old 03-22-09, 07:14 AM   #1
New Member
Alias: phil
Loc: Maryland
User: #4885
Since: Dec 2006
  philmadxx is offline
I have a plan, I just don't know if it is a good one. Most of my decisions were based on what I gather from here and other places on the web.
A little background:
My dedicated basement HT is 14'5"w x 24'8"l x 8'h, there is a riser (2 layers 3/4" ply stuffed with glass) in the back for the second row of seats. Construction is double stud, double 5/8 drywall walls on interior - single 5/8 on 2 exterior (poured walls). Ceiling is 2x 5/8 hanging on RISC clips. Thick padding and carpet on the concrete floor. There is a 48" HVAC bulkhead I have soffits around the perimeter - 13" w x 7"h. The sides are drywall, the bottom is open.
Electronics:
7.1 systems with Onkyo SR 855 (?) driving AV123 850 Rockets and bigfoot in the front, rocket dipoles on the sides and rocket bookshelves in the back. I will have two subs, MFW-15s for now until I build my own. Wiring is everywhere, I planned to have one sub in the front and one in the back, centered on the walls. Panny AE-1000 set up for anamorphic projection, 115" widescreen (TBD), bluray, Direct TV HD are the sources - haven't bought into the HTPC....yet.
The plan:
I was going to install OC 703 in the soffits for bass trapping. I can get it to be 6" x 13" with GOM over it. There will be about 96 lf of this "bulkhead" total around the room.
I also plan deaden the back wall with 2" OC 703, tri traps in the rear corners, 1" on the front wall, first reflection points for both rows, nothing on the ceiling.
Questions:
Do I have a good start for acoustics?
Will the soffits be enough bass trapping?
Do I need something on the ceiling?
I have a CAD file almost done that I think I can change into a suitable-to-post format as well as some pics when I can post them.
Thanks in advance for all of your help!!
Phil
Old 03-22-09, 09:38 AM   #2
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Re: acoustical plan - suggestions wanted
Hi Phil
In the soffit as designed, I'd likely use paper faced wall insulation with the paper exposed to the room to minimize overdeadening the upper mids and highs but still get good bass control. This will also save you a ton of money over 703. Once you get to about 6" and you already have the other things, the density difference doesn't matter so much.
I'd likely use 2" on the front wall.
On the rear, 2" 703 is good. I'd use an FSK facing on this to keep the surround field lively but still get the bottom end control/null control.
If you're just doing visible panels on the side walls, I'd plan on at least 4 2'x4' panels on each side. 2" thick if you can tolerate it.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 03-22-09, 07:59 PM   #3
New Member
Alias: phil
Loc: Maryland
User: #4885
Since: Dec 2006
Thanks Bryan - I was hoping you'd chime in. If I can get away with the standard insulation with a kraft facing in the bulkheads, that saves me a lot of work and money. Is there any advantage to stuffing it and compressing the 'glass?
The 2" on the front wall surprises me, is this for high frequencies? Will the screen affect this, it will be about 48"h x 125"l?
Old 03-23-09, 06:04 AM   #4
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
2" on the front wall is more to help with boundary effects (SBIR). If you can do something behind the screen, that would be great.
In the soffit, you can compress a little if you want. I wouldn't get carried away as you're not really doing much except spending more time and money.
Bryan Pape
GIK Acoustics
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
acoustical, plan, suggestions, wanted
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333
