| Home Audio Acoustics high end sounds so-soDiscuss high end sounds so-so in the Home Theater Installation and Systems forum; high end sounds so-so I was watching 2001 Sunday and during the musical selections I noticed the low end sounded great but the high ... |
Views: 285 - Replies: 3
| high end sounds so-so I was watching 2001 Sunday and during the musical selections I noticed the low end sounded great but the high end sounded a bit harsh. I've got a corner set-up with 5 bass traps spread around any ideas what might be causing the harshness? I've got a Marantz SR-6001 feeding 5 Ascend HTM-200s. ![]() | ||||
| | #2 | ||||
| Re: high end sounds so-so I'd have to know a little more about the room. From what I can see, possibilities include: - Hardwood floor - Speaker in shelf cavity - Potential mis-calibration from the auto-eq function of the receiver. Bryan | ||||
| | #3 | |||||
| Re: high end sounds so-so Quote:
I'm not using auto-calibration just a SPL meter on a tripod to level match the speakers. I choose the HTM speakers because they are small, sealed and sound pretty good but I was worried about the left front being in a 'shelf cavity'. Thanks, Joe Edit: Also, the right front is near a 4'x6' window opening with mini blinds and thin curtains. When watching movies I do keep the windows closed, blinds down and curtains drawn. | |||||
| | #4 | ||||
| Re: high end sounds so-so The vinyl over concrete will react pretty much the same if not worse than a wood floor in terms of high frequencies. I suspect the room is just overly live and needs to be tamed a bit. Bryan | ||||
