| Home Audio Acoustics Theater above basementDiscuss Theater above basement in the Home Theater Installation and Systems forum; Theater above basement I'm converting my living room into a dedicated home theater. The room is 18' x 13.5' and is directly above ... |
Views: 284 - Replies: 6
| I'm converting my living room into a dedicated home theater. The room is 18' x 13.5' and is directly above an unfinished basement, and has a wood floor which is the ceiling for the basement. I plan on carpeting the floor and doing the usual acoustic treatments, but I was wondering about the subs. Should I build something like ASC's subtraps, to decouple them from the floor and also to help with the vertical room mode? | ||||
| | #2 | ||||
| Re: Theater above basement Sounds great. Are you asking with respect to sound staying in the room or regarding the quality of the sound remaining within the room? | ||||
| | #3 | ||||
| Re: Theater above basement All I'm concerned about is obtaining the best possible sound in the room. I live in the country and I'm single, so sound escaping isn't a problem. I was thinking that running a pair of THX Ultra subs in a room constructed this way might equate to a a whole lot of movin and shakein goin on. | ||||
| | #4 | ||||
| Re: Theater above basement I wonder what sort of construction might help you in that respect. A structure built with a resonance point of 50Hz might be a fun ride. That would start a little structural roller coaster starting at 65Hz down to 35Hz. | ||||
| | #5 | ||||
| Re: Theater above basement I think the carpet will definitley help and it might be enough. I would set them up and run the system before getting too worried. If you find that after a sound test you need to do something else you could use something like a subdude by auralex.http://www.google.com/aclk?sa=l&ai=C...s/SUBDUDE.html | ||||
| | #6 | ||||
| Re: Theater above basement The SubDude might be just the ticket, and I am considering that as an option. I read a test report on the ASC subtrap that said that it was very useful, when you had wooden flooring over an open space ( sounds familiar ). The reviewer stated that this flooring arrangement is quite suseptible to flexing, vibration transmission, and self noise ( whatever that means ). Also that it would help with the vertical axial mode, usually at 70 Hz with an 8' ceiling. I'm usually not a DIY kind of guy, but it doesn't appear that it would be to hard to build a combo isolation platform and bass trap. | ||||
| | #7 | ||||
| Re: Theater above basement Carpet may help, but a good flooring like wood would look better as long as its installed properly. scottsdale flooring | ||||
