| Home Audio Acoustics Ducting for Home TheatersDiscuss Ducting for Home Theaters in the Home Theater Installation and Systems forum; Ducting for Home Theaters As Bruce has already stated earlier Mass is the only real way to stop sound from leaving a space. On ... |
Views: 487 - Replies: 27
| | #26 | ||||
| Re: Ducting for Home Theaters As Bruce has already stated earlier Mass is the only real way to stop sound from leaving a space. On the ducting issue remember one thing that every 90 degree turn you make you loose 6% of the airflow to resistance and even more if you use flexible ducting as the bumpy surface (unless stretched out fully) causes resistance as well and increases the noise level of the airflow. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #27 | |||||
| Re: Ducting for Home Theaters Quote:
What are vibration isolators? Is this the rubber device between the top of the furnace and supply duct. One could think it could also be used to connect if alignment isn't perfect between them? I've also thought about isolators between bottom of furnace and floor? Joe | |||||
