Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Should I cram more wall panels in or do the ceiling?
Discuss Should I cram more wall panels in or do the ceiling? in the Home Theater Installation and Systems forum; Should I cram more wall panels in or do the ceiling? With a laminate floor (I'll have area rugs and leather sofas) should I absolutely maximaze 2x4 OC703 panels on the ...
GIK Acoustics
Views: 228 - Replies: 5
Old 09-23-09, 04:05 PM   #1
Alias: Rancho
Loc: New Mexico
User: #40925
Since: Aug 2009
  Rancho5 is offline
With a laminate floor (I'll have area rugs and leather sofas) should I absolutely maximaze 2x4 OC703 panels on the walls or space them out and put a few on the ceiling?
Old 09-23-09, 04:44 PM   #2
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Re: Should I cram more wall panels in or do the ceiling?
Use them sparingly and as required on the side walls. The area rugs should be between you and the speakers. That should pretty well cover things unless the rugs are very small and there's a lot of laminate exposed.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 09-23-09, 07:43 PM   #3
Alias: Rancho
Loc: New Mexico
User: #40925
Since: Aug 2009
  Rancho5 is offline
The exposed laminate will be behind the seating areas. And we will also put some carpet padding under the area rug as it is not that thick.
We are planning on 4 panels on each wall between us and the screen, 8 total. We used a black stretch double knit polyester to cover the panels.
Old 09-24-09, 09:57 AM   #4
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
That should be plenty between you and the screen.
For the rear, you can do a few panels on the ceiling if you want. I'd start without it and see how it sounds first.
Bryan
Bryan Pape
GIK Acoustics
Old 09-25-09, 01:18 PM   #5
Alias: Rancho
Loc: New Mexico
User: #40925
Since: Aug 2009
  Rancho5 is offline
I used a spray adhesive to attach mu OC703 panels to the front screen wall, under the screen, and they fell off this morning. I sprayed both surfaces and allowed to dry for one minute as required.
How do you guys suggest attaching bare panels to the wall? They will be covered by velvet curtains.
Old 09-25-09, 02:13 PM   #6
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
Use a couple of screws with fender washers.
Bryan
Bryan Pape
GIK Acoustics
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
ceiling?, cram, panels, wall
