Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Acoustic panels
Discuss Acoustic panels in the Home Theater Installation and Systems forum; Acoustic panels I finally finished the structure and I'm looking for advice on acoustic panels for the wall.I was thinking maybe three ...
GIK Acoustics
Views: 169 - Replies: 7
Old 11-01-09, 11:36 AM   #1
Alias: BRYAN
Loc: louisville
User: #30713
Since: Dec 2008
  realtor416 is offline
Acoustic panels
I finally finished the structure and I'm looking for advice on acoustic panels for the wall.I was thinking maybe three on each sidewall about 3 x4 ft. made out of a 2x2 frame cover it with fabric and fill it with
some type of sound absorbing material.Any suggestions on it or anything else to make it better?
Old 11-01-09, 12:08 PM   #2
Alias: Jason
Loc: Ohio
User: #22724
Since: Jul 2008
  Jason_Nolan is offline
Re: Acoustic panels
GIK acoustics sells them cheap if you cant make them yourself. I recently purchased some and they help the sound tremendously.
Talk to Bryan Pape on here. Very helpful.
Old 11-01-09, 12:09 PM   #3
Alias: Jason
Loc: Ohio
User: #22724
Since: Jul 2008
Re: Acoustic panels
You may take some measurements with REW and some waterfalls to see what your problem areas are.
That would help anyone making recommendations to you.
Old 11-01-09, 12:51 PM   #4
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Re: Acoustic panels
#1 Broadband bass absorbers in the front corners.
#2 Completely deaden the front wall
#3 Reflection panels as you described. Try to get a full 2" thick if only doing 3 panels per side.
Fill material would be 2.5lb-4.5lb mineral wool, 3lb fiberglass board, or 3lb acoustic cotton.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 11-02-09, 06:22 AM   #5
Alias: BRYAN
Loc: louisville
User: #30713
Since: Dec 2008
Re: Acoustic panels
Thanks Bryan, what would I use to deaden the front wall?
Old 11-02-09, 07:03 AM   #6
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
Re: Acoustic panels
The room looks relatively long and the speakers relatively close to the front wall - pretty much the same 2" material would be appropriate.
Bryan
Bryan Pape
GIK Acoustics
Old 11-02-09, 05:21 PM   #7
Alias: BRYAN
Loc: louisville
User: #30713
Since: Dec 2008
Re: Acoustic panels
Bryan, to deaden that wall does that mean I need to completely cover it or will panels work?
Sorry for all the questions i'm not even a novice yet.
Old 11-02-09, 05:25 PM   #8
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
Re: Acoustic panels
No problem at all. You can do it however you want as long as it's dead. If you do panels, it will just take quite a few of them. You want it completely covered.
Bryan
Bryan Pape
GIK Acoustics
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
acoustic, panels
