Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater Installation | Systems > Home Audio Acoustics
  Discuss Do clips, GG, DD make a difference inside the room? in the Home Theater Installation | Systems forum; Do clips, GG, DD make a difference inside the room? Just as the thread title states, do Whisper Clips, Green Glue, double drywall, etc. make a difference inside the room ...
Views: 257 - Replies: 13
Old 11-05-09, 10:08 AM   #1
Alias: Dave
Loc: Maple Grove, MN
User: #42505
Since: Sep 2009
  slow.junk is offline
Just as the thread title states, do Whisper Clips, Green Glue, double drywall, etc. make a difference inside the room or are they used merely to limit sound transmission through walls? I understand that the addition will reduce incoming noise, but if I have a perfectly quiet house it won't make a difference, right? On the flip side, the addition will reduce outgoing noise from the HT as well, but if I'm the only one home it doesn't matter, right? Reason I ask is I'm trying to calculate the cost of building a new HT and all the articles I read about soundproofing is to eliminate the transmission of it and nothing is mentioned of improving sound quality within the room so I would not want to spend ~$2k on clips, GG, and DD unnecessarily.
Thanks!
- still trying to figure it all out...
Old 11-05-09, 10:17 AM   #2
Shack Moderator
Alias: Ted White
Ted White's Avatar
Loc: Michigan
User: #37110
Since: May 2009
  Ted White is offline
Re: Do clips, GG, DD make a difference inside the room?
If you have no need to isolate the sound then definately don't bother
Old 11-05-09, 01:34 PM   #3
Alias: Dave
User: #42505
Since: Sep 2009
Ted White wrote: View Post
Thanks Ted.
Old 11-05-09, 01:37 PM   #4
Shack Moderator
Alias: Ted White
Ted White's Avatar
Loc: Michigan
User: #37110
Since: May 2009
You're quite welcome
Old 11-05-09, 02:16 PM   #5
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
slow.junk wrote: View Post
... I have a perfectly quiet house it won't make a difference, right?
... the addition will reduce outgoing noise from the HT as well, but if I'm the only one home it doesn't matter, right?
You reasoning is correct, if you don't feel the need of using GG, clips, DD, etc. don't do it. If you're always home alone and the noise won't bother anybody else, save your $$$.
...the articles I read about soundproofing is to eliminate the transmission of it and nothing is mentioned of improving sound quality within the room ...
I think this is correct, soundproofing will tell you how to eliminate the sound transmission, to help you improve the sound I think you need to read more about "Room treatment with accoustic treatments"
I'm sure that you can use part of the $$$ you'll save to treat your room.... start with some panels and see if that helps.
Old 11-06-09, 09:08 AM   #6
Shack Moderator
Alias: Greg
glaufman's Avatar
Loc: NY
User: #13758
Since: Nov 2007
  glaufman is online now
salvasol wrote: View Post
+1
Old 11-06-09, 12:00 PM   #7
Alias: Dave
User: #42505
Since: Sep 2009
Great, thanks guys. The room will be fully treated on the inside and I just wanted to make sure that I wasn't missing out on improvement by skipping the clips, GG, etc. The HT is in the basement with the kitchen above it and then the bedrooms another level up so you don't hear anything up there.
Old 11-06-09, 12:29 PM   #8
Shack Moderator
Alias: Ted White
Ted White's Avatar
Loc: Michigan
User: #37110
Since: May 2009
Please don't forget to account for ventilation isolation, the doors and any penetrations like outlets.
Old 11-06-09, 02:49 PM   #9
Alias: Dave
User: #42505
Since: Sep 2009
For outlets, does a spray foam (such as Great Stuff) work at sealing them? Or is that not enough?
Old 11-06-09, 02:54 PM   #10
Alias: Dave
User: #42505
Since: Sep 2009
Another question: if I had the budget to do only Whisper clips or Green Glue, which would havethe better bang for the buck in terms of isolation? (Both assuming dual layers of 5/8" drywall)
« Home Theater Shack > Home Theater Installation | Systems > Home Audio Acoustics »
clips, difference, inside, make, room?
Bookmark and Share
Dish Network
