Sound insulating a new recording studio - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Discuss Sound insulating a new recording studio in the Home Theater Installation and Systems forum; Sound insulating a new recording studio Hi all, my name is Quinto and, before of all, I beg you pardon for my english writing. It was ...
GIK Acoustics
Old 11-07-06, 04:06 AM   #1 (Link)
Alias: Quinto Sardo
Loc: Italy
User: #3326
Since: Oct 2006
quintosardo is offline
Hi all,
my name is Quinto and, before of all, I beg you pardon for my english writing. It was from school, now it is from international forums, which is terrible
I'm designing and building our new studio. We are 6 men and 2 women, we registered a company ("SK") and started with this new adventure.
It will be a commercial studio.
We have a relatively low budget, I'm sure that this makes the design a lot more interesting, because it is what most people has.
I've looked for the place, convinced people, looked for docs (I'm an engineer but i hadn't specific background), designed the studio, designed the furnitures, used a big hammer to remove existing walls, looked for waste removal, bought materials, bought instruments, built devices like preamps.
I'm going to build the insulation and devices for acoustics.
I'd like to show the progresses here, because I like "internet collaboration" a lot and because I'd like to get some advice (I could be wrong in some critical points).
This is what we are going to build (drawings and photos will be on www.skstudio.it as long as works will go on):
- we have a single room: 21m x 5m x 3.15m(h)
- there is a single door on one side, 4.5m wide
- we decided to build a recording room in the opposite side to entrance, 5 x 8m
- on the short side (5m) there will be the control room, 4m wide x 5m long
- resulting height after insulation will be 2.80m
We will build a structure with iron, then we will build dry walls and ceiling on it.
These are the materials for walls:
- drywall 1,3cm + rockwool 120 kg/m3 6cm + rockwool 40 kg/m3 4cm + drywall coupled with lead
These are the materials for ceiling:
- poliuretan-metal composite panels (used for external ceilings)
- rockwool 120 kg/m3 6cm + rockwool 40 kg/m3 4cm + drywall coupled with lead
We are still considering the alternative of replacing lead for ceiling with resonating panels (built by ourself)
The ceiling will be placed over the structure, the walls will be placed inside.
Floor:
The room is at "zero level", but there is the structure under the floor, we found that jumping on the floor we can feel the walls vibrating, so we decided to insulate it
- 1cm "isolgomma R" (www.isolgomma.it)
- 2cm wood
- 0.5cm isolgomma
- 1cm wood
- parquet (or wood, instead of 1cmwood + parquet)
Windows:
- two glasses angled about 20° each other and placed 10cm min apart
Doors:
- a couple of REI120 for recording room and a single REI120 for control room
Between drywalls, panels and iron: bi-adhesive rubber band
Between iron structure and floor: the same as floor (rubber+wood+rubber+wood)
This is the raw description of what we are going to do. Today I'm going to receive the iron, to be soldered in place.
Sorry for this huge post!
I'll be able to post some drawings and photos in a while.
There is a very long work behing all this, because I had to design while looking for available materials and a lot of other aspects, of course.
I'm going to tell about acoustic control in a nother thread, because I feel it like a completely different argument (even though it isn't independent, of course)
Any comment/advice will be very appreciated, and I'll be happy to answer to any question about materials and anything else.
Quinto
Old 11-07-06, 04:25 AM   #2 (Link)
Alias: Matthew
Loc: London
User: #2697
Since: Sep 2006
Matthew Moore is offline
Re: Sound insulating a new recording studio
Hi Quinto. Welcome to the forum!
A lot of info in your post.
Perhaps you could break it down a bit for us and ask a couple of questions at a time?
A studio build diary would be great!
I'm not really a building expert but I'm sure the folks here will be happy to help.
Good luck
Matthew
Old 11-07-06, 04:32 AM   #3 (Link)
Alias: Quinto Sardo
Loc: Italy
User: #3326
Since: Oct 2006
Hi Matthew
yes, I'll break it down for sure, I wanted to give a complete view as a starting point
The "studio build diary" is the right concept and it is what I'm going to do, I sould be able to upload the first snapshots and a general drawing tomorrow...
Old 11-07-06, 04:39 AM   #4 (Link)
Alias: Matthew
Loc: London
User: #2697
Since: Sep 2006
Hi Quinto. That's great. Looking foward to the pictures. Sounds like you have a great project ahead of you.
And by the way, your english is fine
Matthew
Old 11-07-06, 04:46 AM   #5 (Link)
Alias: Dan
Loc: Australia
User: #359
Danny is offline
For a studio you really do not want to allow any sound to get in from outside the studio. Double glazing and good rubber compression seals around your windows and doors will help reduce this problem for a small price.
Old 11-07-06, 05:22 PM   #6 (Link)
Alias: B-Dogg
Loc: East Coast, USA
Bryan Nemecek's Avatar
User: #1768
Bryan Nemecek is offline
Smile Re: Sound insulating a new recording studio
Will you be making an English version of your website?
I was there, and I'm sorry I don't understand Italian.
Sounds like your studio is quite the undertaking. Why are you using lead in your construction? What thickness is the lead and is the drywall attached to the lead?
Ahh, great coffee!!
Old 11-08-06, 05:23 AM   #7 (Link)
Alias: Quinto Sardo
Loc: Italy
User: #3326
Since: Oct 2006
Bryan Nemecek wrote: View Post
Hi, thanks
I'll do an english version for the "studio construction diary". I'll try to do some other pages in english. www.sknote.it is in english because it is for worldwide application, while www.skstudio.it is in italian because it is born for "local" application. I'll try to keep the "non-local" pages in english, too...
I'm using lead because I need to stop low frequencies. It needs mass and lead seems to be the only true solution.
I'm going to use drywall coupled with lead. The same used for x-ray rooms but with less lead.
I will install 0.5mm lead.
I'm going to use resonating membranes, too, for low frequencies
Old 11-08-06, 05:28 PM   #8 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Have you seen anything to indicate if that will work or not? Just curious, because as far as I know, “mass” typically means at least a few inches of concrete.
Old 11-09-06, 10:19 AM   #9 (Link)
Alias: Quinto Sardo
Loc: Italy
User: #3326
Since: Oct 2006
No direct experience (I'll do a lot of tests while building this studio) but this is a good reference:
http://www.ndasrl.it/schedaprodotto.asp?ID_Prodotto=6
There are curves for several materials, there...
Old 11-09-06, 10:44 AM   #10 (Link)
Alias: Quinto Sardo
Loc: Italy
User: #3326
Since: Oct 2006
I just wanted to show you our great recording studio:
(I'm the tall one )
This is to say: don't think it's easy
Old 11-09-06, 10:56 AM   #11 (Link)
Alias: Quinto Sardo
Loc: Italy
User: #3326
Since: Oct 2006
The snapshot is good. We were removing concrete with the hammer so the flash reflected on the powder...
On the right: we are building the furnitures, you can see the console with racks and audio monitor shelves
On the left: iron (for the structure for playing room and monitoring room) and rubber (for the floor)
This is the starting point of our studio-building-diary...
Old 11-13-06, 03:06 AM   #12 (Link)
Alias: Quinto Sardo
Loc: Italy
User: #3326
Since: Oct 2006
The works go on...
Preparing insulation between the structure and the floor (waiting for the glue to make effect)...
Old 11-15-06, 01:27 AM   #13 (Link)
Alias: Boyce
User: #480
boyce is offline
Hi quintosardo, from your photo, I believe you are building a new wall which will line up the room as a box, we did build some home studio, most time we like to make the wall not parallel, especially for a small room, just off set one side of the wall couple degree, it will save you lot of time to look for the mic sweet spot.
Old 11-20-06, 02:42 PM   #14 (Link)
New Member
Alias: Andrew
Loc: Sheffield UK
User: #4155
Since: Nov 2006
Andrew W is offline
Non- Parallell Walls Myth-
This will surely be too late to help but might help others - do not fall into the non-paralell walls trap. All that NP walls do is make identifying and taming room modes more difficult if not downright impossible without serious test equipment eg Linear-X, and you can finish up chasing problems for evermore. By having a regular room you can easily identify immediate mode problems by calculation.
Old 11-20-06, 07:13 PM   #15 (Link)
Alias: Boyce
User: #480
boyce is offline
Andrew W wrote: View Post
Can you provide more detail about Linear-X? Don't understand which serious product you use? For our job, we alway build the wall non -paralell, after drywall / carpet, it will take us about 2 - 4 hours to do the test / calculation with DIRAC software. Why non-parallel is a trap?!!
Old 11-20-06, 08:40 PM   #16 (Link)
Alias: brucek
User: #6
brucek is offline
That's the first time I've heard this. It's not that I doubt it, but my understanding is that 4 non-parallel walls don't allow any standing waves a chance to build.
Here's a small article that fits nicely into my novice knowledge of the subject.
Non-parallel walls
RR Audio designs enclosures based upon the fact that parallel walls cause standing waves inside the enclosure which cause certain frequencies to predominate at wavelengths based upon the distance between the walls. These frequencies and their harmonics will cause reinforcement (or cancellation) which causes peaks (or dips) in the frequency response. Depending upon the bandwidth of these resonances, there will be energy storage and ringing at these frequencies to some extent (a great deal if the resonances are high-Q). By designing the enclosures with non-parallel walls, the wavelengths between opposite walls are different at any two adjacent points, which spreads the frequencies associated with these wavelengths and eliminates standing wave modes. The reduction in midrange distortion and frequency response anomalies is significant. In addition, the rear-wave energy from the LF driver is bounced on paths which do not immediately re-contact the diaphragm. The energy is bounced all around the interior of the enclosure, encountering damping material at each wall which absorbs much of the energy, so when it finally recontacts the diaphragm, the amount of energy is greatly reduced from the original level. This reduces the phase distortion caused by rear-wave energy creating vibrations in the diaphragm which have no relation to the current audio signal, and substantially improves transient detail performance, low-level detail retrieval, and clarity.
Old 11-21-06, 12:28 AM   #17 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Hmm... As far as I know, the reason for non-parallel walls in studios has to do with reflections, not standing waves. It should be easy to find and deal with those with a program like REW.
Old 11-21-06, 01:22 PM   #18 (Link)
Alias: Ethan Winer
Loc: New Milford, CT, USA
Ethan Winer's Avatar
User: #1679
Ethan Winer is offline
Wayne,
> As far as I know, the reason for non-parallel walls in studios has to do with reflections, not standing waves. <
Exactly. It's common in professional control rooms for the side walls to angle outward by 30 to 35 degrees or so, which deflects all first reflections toward the back of the room. Non-parallel walls are neither good nor bad from the perspective of bass frequencies. And you can still determine "good" dimensions whether the walls are parallel or not.
That said, the biggest mistake I see people make is building a room with the corners cut off at an angle. Whether the room is parallel or not, whatever you do please leave the corners as corners! Otherwise you've just removed the single best place to put bass traps.
--Ethan
RealTraps
Old 11-21-06, 02:44 PM   #19 (Link)
Loc: Lower Alabama
Ethan Winer wrote: View Post
What about if you cut out a big section (a wide slot of sorts) out of the cut-off corner and load it with absorbing materials, then cover it with panels? Seems like that would be a good bass trap.
Sonnie
Old 11-21-06, 07:29 PM   #20 (Link)
Alias: Boyce
User: #480
boyce is offline
Hi Ethan
After I did read some information from your web ( When the budget allows for dedicated construction, early reflections can be avoided by angling the side walls and sloping the ceiling upward. The control room at left was designed by noted studio designer Wes Lachot, and offers a beautiful example of such construction. Given a large enough angle - at least 35 degrees - the reflections are directed behind the listening position without having to apply absorbing materials to the walls or ceiling. This lets you better control the overall ambience in the room because you don't need additional absorption just to get rid of the reflections. But most people do not have the luxury of building new walls, so the only option is to apply absorption at key locations.)
From your professional opinion which way you will perfer?
Old 11-27-06, 07:55 PM   #21 (Link)
Alias: B-Dogg
User: #1768
Talking Re: Sound insulating a new recording studio
Sonnie wrote: View Post
A studio in Los Angeles did just that. It took out the entire center section of the back wall, but left the corners intact.
The trap had 8 fibercovered panels hanging from ceiling on chains at 45 degree angles (4 looking left and 4 looking right).
It was some 4 feet deep. Can't recall the width.....
Each main monitor speaker (soffit mounted) contained:
two 15" woofers and 1 HF driver.
We needed a trap that could handle what the main monitors could put out.
A pair of Yamaha NS-10M speakers would live on top of the mixing board. I spent more hours on those than the big main monitors.
I actually like that room alot. It sounded 'bigger' than it really was. Thanks in part to really good room construction and room voicing.
~Bryan
Ahh, great coffee!!
Old 11-28-06, 01:55 PM   #22 (Link)
Alias: Ethan Winer
User: #1679
