Any advice before I drywall - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Discuss Any advice before I drywall in the Home Theater Installation and Systems forum; Any advice before I drywall Hey guys, I am almost done framing my basement HT out and I am in the process of getting some ...
GIK Acoustics
Old 03-30-07, 06:59 PM   #1 (Link)
Alias: rob
Loc: palmyra, pa
robk_11's Avatar
User: #6308
robk_11 is offline
Hey guys,
I am almost done framing my basement HT out and I am in the process of getting some bids on getting the drywall done. I was going to do it myself but I am actually getting tired of swinging the hammer ! My question is does anyone have any recommendations on some accoustical treatment pre-drywall? My walls are Superior walls (precast concrete) that already have R13 insulation as part of their build. On top of that I put in some R 13 bat insulation. Anything else I should do that would help my "skeleton" before I/or a contractor sheet rock?
thanks,
Rob
Old 03-30-07, 09:12 PM   #2 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Re: Any advice before I drywall
Not really - that's a good core. Make sure when they drywall that they seal up all the boxes tight.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 03-31-07, 12:31 AM   #3 (Link)
Alias: Bill
Loc: Michigan
User: #636
11B2P is offline
One thing (of many things!) I wished I had done before hanging the drywall in my basement media room was to soundproof the HVAC ducts in the ceiling. (I have a drywall ceiling so I can't get to the ducts without tearing it down.) I would have used some type of mass loaded vinyl to help stop sound transmission along the duct.
Here is an example of what I mean: http://www.soundproofing.org/infopages/flooring.htm
I would hang some of this with staples under the duct for the length of the joist space the duct is in to "seal it up". Kind of like capping the "u" shape the joists make. You could also use some of this in your cold air return wall space.
You also might consider using RC-1 channeling under your drywall to reduce sound transmission from the drywall to your wall studs.
More information can be found here: http://www.soundisolationcompany.com...n-channels.php
-Bill M.
Old 03-31-07, 05:46 AM   #4 (Link)
Alias: John
Loc: mukwonago
User: #5253
Since: Jan 2007
John N is offline
I wish I would have doubled the drywall (and Green Glue) on the ceiling in the rec rm. You will wish you had the first time you sit down with your favorite beverage ,pizza and dvd and they say "could you turn that down"
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
Panel Placement Advice Tukkis Home Audio Acoustics 9 03-03-07 01:17 PM
Looking for advice on my room... allredp Home Audio Acoustics 5 02-09-07 12:21 AM
Generic Advice on Accoustics JCD Home Audio Acoustics 23 10-27-06 04:50 AM
Need Sound Design Advice Sthrndream Home Theater Design and Construction 10 09-25-06 01:06 PM
Component Rack Advice Tommy Remotes | Cables | Accessories 10 06-12-06 09:47 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
