Bass traps or EQ - Page 3 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Bass traps or EQ
Discuss Bass traps or EQ in the Home Theater Installation and Systems forum; Bass traps or EQ That's exciting F1--could you post some pics of your "treated" room for us? Thanks, Phil...
GIK Acoustics
Old 02-28-07, 07:21 AM   #51 (Link)
Alias: Phil
Loc: Idaho
allredp's Avatar
User: #6382
allredp is offline
Thumbs up Re: Bass traps or EQ
Thanks,
Phil
Dali Mentor 8/Vokal/Ikon Phantom 5.1; SVS pb13 Ultra; Sherbourn 7/2100A bridged 3 channels for 400+ watts to L/C/R & Onkyo 875 pre-pro & surround amp = Audio Heaven!
Now about that projector...
Old 02-28-07, 06:44 PM   #52 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
Ok here are some pics.
Old 02-28-07, 06:50 PM   #53 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
A few more.
Old 02-28-07, 07:08 PM   #54 (Link)
Bronze Supporter
Alias: jack
Loc: Chicago Suburbs, IL USA
basementjack's Avatar
User: #2649
Since: Sep 2006
basementjack is offline
HOT DOG F1!
Did you build all these traps since you started with the corner traps at the beginning of this article?
- Jack
Old 02-28-07, 07:13 PM   #55 (Link)
Alias: Phil
Loc: Idaho
allredp's Avatar
User: #6382
allredp is offline
Nice job, F1. You inspire us...
Old 02-28-07, 07:37 PM   #56 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
Thanks Jack and Phil.
basementjack wrote: View Post
No just the 4 corner traps. I built the others previously.
Old 04-12-07, 07:30 PM   #57 (Link)
crg
New Member
Alias: Charles
Loc: NJ
User: #6272
crg is offline
I am building 88" 24x17 corner traps. I was wondering if you have any tips on stretching the fabric. I built frames last night and will order some 703 and GOM over weekend.
Old 04-12-07, 09:54 PM   #58 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
Hi crg,I bet those large traps will work great.
As far as tips , I just started on one side and secured the fabric the full length of the frame with an electric staple gun.I then pulled it as tightly as possible to the one side then stapled it.Then the top then the bottom.Im not sure about the GOM but the fabric I used was very strecthy so it was easy to get tight so that there were not any wrinkles.
Good luck and when you get them done be sure to post some pictures.
Old 04-16-07, 06:26 PM   #59 (Link)
crg
New Member
Alias: Charles
Loc: NJ
User: #6272
crg is offline
Well, I got the frames done this weekend (with a little help).
Old 04-16-07, 07:35 PM   #60 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
Wow those are huge,I wish I had the space for something that big.NicelyDone.
btw your helper is a little cutie.
Old 04-17-07, 06:35 PM   #61 (Link)
crg
New Member
Alias: Charles
Loc: NJ
User: #6272
crg is offline
Thanks for the compliments. Lucky for her she looks like her mother.
Looks like it will take a few weeks for the 703 to get here so I'll post more pics then.
Old 04-22-07, 08:14 PM   #62 (Link)
crg
New Member
Alias: Charles
Loc: NJ
User: #6272
crg is offline
The fiberglass came in sooner than I thought it would. I cut it up and filled the cavities of the two 88" ones today. I had 1 panel left and set it in the front of the smaller 48" trap. Used a utility knife and electric carving knife as suggested elsewhere.
I have some left over 1/2" linacoustic that I hoping to attach to the front so that when I cover it it will produce a smooth surface. Also, while I understand its best to fill the cavity of the 48" in corner trap, especially since its only 1 panel 2" thick, will filling it with left over linacoustic work well or is there somethingelse I should consider that I can get from HD or Lowes?
Old 04-24-07, 08:09 AM   #63 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
hey F1, do you have pics of the backsides of your DIY creations?
the corner trap, wall panel, and free standing panels?
Old 04-24-07, 08:27 AM   #64 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Filling with Linacoustic would provide some benefit - though not as much as 703 in the deepest octaves.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 04-24-07, 06:59 PM   #65 (Link)
crg
New Member
Alias: Charles
Loc: NJ
User: #6272
crg is offline
Well I finished the two larger traps. I did not use GOM due to expense and used burlap instead. I was largely pleased with the finished results except the edges. I may re-wrap it later after working on my technique a bit with the smaller trap.
I think my mistake was that I cut the top and bottom of the frame for exactly a 24" width & 17" sides. When I cut the 703, the front corners extend just bit past the frame. For the smaller frame I am going to make plates an inch or 2 longer to see if that will work.
Any way attached are some pics. Once in the room they really blend in nicely. I finished before the wife got home. Took her down to the room and she did not immediately detect what was different (a major plus).
Old 04-24-07, 07:26 PM   #66 (Link)
crg
New Member
Alias: Charles
Loc: NJ
User: #6272
crg is offline
I recalibrated the system and got to listened to a few tunes (Neena Freelon - Soulcall) before the wife callde me to eat. This is a piece of work I enjoy lstening to every now and then. The cello on Better Than Anything seems to have more definition and a little more punch. Good start1
Attached are before and after REW graphs. The before was with 1st reflection point and rear traps in place. "After" adds front corner traps to the "Before".
Old 04-24-07, 07:26 PM   #67 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Lookin good! Yeah - it's not an exact science. An extra .5" here and there will gain you a ton of looks. Though, I will say that they look nice in the room
Bryan
Bryan Pape
GIK Acoustics
Old 04-24-07, 07:51 PM   #68 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
mike c wrote: View Post
Sorry Mike I don't have pics of the backs but if you look at post #15 in this thread you can see how the frame of the corner trap covers the back almost completely.The free standing panels are open in the back except for 2 4"wide strips of hardboard (masonite) runing from top to bottom on each side to hold the mineral wool in place.The backs of the wall panels are completely covered with masonite.
crg,those traps do blend in nicely with the room.It looks like you have a real nice setup.
Old 04-24-07, 10:23 PM   #69 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
thanks for the info F1.
Old 04-25-07, 08:52 AM   #70 (Link)
Alias: brucek
User: #6
brucek is offline
crg, I believe that you are using the old Radio Shack meter calibration file. Best to use the new one that associates with your model found here. The files are new in the last month after Sonnie had his ECM microphone professionally calibrated and we re-did the files.
I really think your low frequency response can be bettered by equalization. You have a nasty peak around 28Hz and others that could be easily corrected with a BFD. There's nothing wrong with correcting very low frequency peaks with equalization. Certainly well executed acoustic treatment improves response over a larger physical area than does EQ, but at very low frequency peaks (such as you appear to have), the size of the treatment would be huge. A cut filter with a matching Q and inverse gain would help reduce the peak.
When you post your graphs use a vertical scale of 45dB-105dB. The RadioShack meter is not reliable above 5Khz, so no use using a horizontal scale that goes to 30KHz. In this case where we are looking for effect of a low frequency mode, perhaps use a horizontal scale of 15Hz to about 500Hz (and measure same to look for low frequency modes).
Old 04-25-07, 09:32 AM   #71 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Agreed. Looks like 4 bands of parametric would bring things pretty nicely in line. The treatments will help quite a bit and deal with the decay time part of the equation. The EQ is the finishing touch to deal with the last few stubborn peaks that can be caused by any number of things.
Bryan
Bryan Pape
GIK Acoustics
Old 04-25-07, 10:08 AM   #72 (Link)
gto
New Member
Alias: gerd
Loc: austria
User: #8476
Since: Apr 2007
gto is offline
F1 fan wrote: View Post
Here is the finished product.I plan to mount them on the upper half of the corner and may add a solid pine end cap on them to dress them up a bit.
Is there a reason why you built it not with facing the corner in the room? Would be more efficient.
Lamda 1/4
br Gerd
Old 04-25-07, 09:02 PM   #73 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
gto wrote: View Post
Lamda 1/4
br Gerd
Hi gto,sorry Im not really sure what you are asking,but to clarify it is triangular shaped so it is meant to fit tight into a corner with the absorbative side facing into the room.
If it were a regular 4" flat panel then straddling it across a corner so that there was an air space behind it would increase it's effectiveness.
Old 04-26-07, 01:00 AM   #74 (Link)
New Member
Alias: Tiger
Loc: S. Cali
User: #8423
Since: Apr 2007
Tigerkn is offline
Hello F1 fan,
If it is not too much trouble, could you please post steps of making it and materials also cost?
Your help is greatly appreciated!
Kev.
Old 04-26-07, 04:02 AM
