Acoustic Material - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Acoustic Material
Discuss Acoustic Material in the Home Theater Installation and Systems forum; Acoustic Material I have searched and searched for OC 703 /705 in my area to no avail.I did however find a mineral ...
GIK Acoustics
Old 01-30-07, 11:34 AM   #1 (Link)
Alias: Frankie
Loc: Manteca CA
User: #5244
Since: Jan 2007
Ciscokid is offline
Acoustic Material
I have searched and searched for OC 703 /705 in my area to no avail.I did however find a mineral fiber called Thermafiber Safing. Has anyone ever heard of this? I can not find any acoustical information on this product. It comes in 2x4 sheets 3inches thick.
I am finally ready to build some bass traps for my room.I was just wondering if anyone is familar with this product.Thanks.
Old 01-30-07, 12:10 PM   #2 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Re: Acoustic Material
Is Thermafiber the brand name? Not familiar with it. If you can find out the density, you can probably extrapolate an approximate performance level. Just understand that any mineral fiber with similar density to 703 or 705 isn't going to be very rigid.
Did you also try to look for the comparable Johns Manville or Knauff 3lb/cu ft rigid fiberglass boards?
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 01-30-07, 12:24 PM   #3 (Link)
Alias: abhi
Loc: SF Bay Area, CA
User: #948
Since: Jun 2006
abhi is offline
I guess Accurate Firestop (Javier) @ Hayward carries Roxul boards at a very reasonable price. I read it in some forum. I contacted him once but didn't get a chance to go and take a look at the boards.
Old 01-30-07, 12:30 PM   #4 (Link)
Alias: abhi
User: #948
Since: Jun 2006
abhi is offline
bpape wrote: View Post
Bryan
Here is the pdf for Safing:
http://www.thermafiber.com/pdfs/TF612.pdf
It doesn't talk about acoustic properties though.
Old 01-30-07, 01:43 PM   #5 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
No - and it doesn't give me density either.
This is the most I could find on Thermafiber.
Thermofiber 1" 4pcf 0.06 0.24 0.58 0.81 0.85 0.90
Thermofiber 1" 6pcf 0.07 0.24 0.62 0.87 0.91 0.91
Thermofiber 1" 8pcf 0.10 0.37 0.82 0.97 0.91 0.89
Thermofiber 1" 12pcf 0.09 0.31 0.77 0.96 0.99 0.94
Thermofiber 2" 4pcf 0.24 0.68 1.08 0.99 0.92 0.92
Thermofiber 2" 6pcf 0.32 0.81 1.09 1.02 0.94 0.94
Thermofiber 2" 8pcf 0.35 0.84 1.04 0.96 0.93 0.93
Thermofiber 2" 12pcf 0.40 0.79 0.94 0.94 0.87 0.87
Thermofiber 4" 2.5pcf 0.63 1.15 1.15 1.05 1.05 0.94
Thermofiber 4" 4pcf 0.77 1.14 1.15 1.04 1.04 0.94
Thermofiber 4" 6pcf 0.84 1.11 1.11 1.05 1.05 0.93
Bryan
Bryan Pape
GIK Acoustics
Old 01-30-07, 02:41 PM   #6 (Link)
Alias: Frankie
Loc: Manteca CA
User: #5244
Since: Jan 2007
Ciscokid is offline
Thanks for the information. I did come across this PDF for thermafiber.The only issue is I am not sure what product this is for since they make several different products. They have the Safing which I can get. They also have an sound attenuation blanket and a curtain wall insulation. I would think they are probably pretty similar.
I think I might check into some of the other products you guys have discussed and see if they are available in my area.
Old 01-30-07, 04:40 PM   #7 (Link)
Alias: jack
Loc: Chicago Suburbs, IL USA
basementjack's Avatar
User: #2649
Since: Sep 2006
basementjack is offline
2 things:
1) rigid insulation is typically available from a few types of places...
- furnace supply shops sell it - it's used to make ductwork in some cases...
- insulation supply shops sell it - look in the yello pages for insulation supply or insulation distributor.
2) don't get hung up on which exact panel to purchase and use. while there are some differences, they should be taken with perspective
- if you want guaranteed, documented performance, buy a GIK panel or a realtrap -both of those companies have done thier homework... yet even with both of those companies fine product - both will openly tell you - it takes ALOT of panels to make a room perfect.
- so take that into consideration - it's not like you if you research and find the perfect 703, that one panel will fix your problems - You'll do far better off with multiple panels of just about anything - if the specs are furnished try for something close to 6 pound per cubic foot, but if it's 3lb/ft don't sweat it.
and buy as thick as you can tolerate, and lastly, plan for them to be away from the walls - even if it's only a little bit - some of the biggest bang for your buck is a piece put diagonally in the corners.
Hope that helps - and please have a look at the site sponsors (GIK acoustics is one of them- and they practically give those panels away!)
- Jack
- Jack
Old 01-30-07, 04:44 PM   #8 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
You should be able to find semi-rigid fiberglass locally. Look in the phone book under _commercial_ insulation companies. Not residential.
Old 01-30-07, 06:17 PM   #9 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
You've gotten some good advice. I will clarify one thing. The density of the material to be used for optimal performance in a given application depends on a few different things. The biggest of those things is how thick you'll be making them.
As an example, 705 is basically double the price of 703 (6lb vs 3lb). So, given a choice, I'd rather have a 6" thic absorber from 703 than a 4" thick absorber from 705. The 6" 703 will perform better and 25% less. Now, by the time you get to that stage, you can (with the same amount of 703 for the same height and size of absorber, you can build a solid chunk that will do MUCH better below 80Hz than 6" straddling. Why? Because at it's deepest point, it's a solid 12" thick.
Another example is when making reflection point panels. If your speakers are far away from the side walls, then your angles of incidence for the reflections are relatively steep. However, if you're close to the side walls, there are some really shallow ones. 6lb material has a tendency to allow high frequencies to skip off at shallow angles of attack - 3lb not nearly so much.
It would be great if there was a single best product for everything - unfortunately there isn't. The reason most people use 703 is because it's a good all around product that can be used for pretty much anything and the cost is at least somewhat reasonable.
I appreciate the kind words about our product. I'm more than happy though to help with DIY projects also.
Bryan
Bryan Pape
GIK Acoustics
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
Rock wool vs. Acoustic cotton vs. OC703 BoomieMCT Home Audio Acoustics 13 03-02-08 04:32 AM
DIY Acoustic Panels southworth Home Audio Acoustics 4 12-01-06 02:03 PM
Acoustic Treatment Project jagman Home Audio Acoustics 17 10-08-06 05:20 PM
General Acoustic Terms - SBIR bpape Home Audio Acoustics 0 09-20-06 08:58 AM
ATS Acoustic panels / superb performers!!! pearsall001 Home Audio Acoustics 7 09-07-06 04:45 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
