Good results with GIK 244 and R-13..one question about corners.. - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Discuss Good results with GIK 244 and R-13..one question about corners.. in the Home Theater Installation and Systems forum; Good results with GIK 244 and R-13..one question about corners.. Hi! I plan to complete my GIK setup when I move but for the time being I am using 2 ...
GIK Acoustics
Old 02-06-07, 02:03 AM   #1 (Link)
Alias: Shaolin95
User: #3303
Since: Oct 2006
shaolin95 is offline
Hi!
I plan to complete my GIK setup when I move but for the time being I am using 2 of the 244 panels and 8 R-13 fiberglass bags (4 in each front corner). The difference is great.
I can still fit 2 more bags in each front corner to make it reach the ceiling. My question is, how much will that help?
At the moment the rear corners have speakers so I cant add any bags there.
Thanks
Old 02-06-07, 05:43 AM   #2 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Re: Good results with GIK 244 and R-13..one question about corners..
Since you're getting it free, go for it. If you can fit 2 more bags, that means at this point you're probably only half way up. The extra will help considerably. 2 corners floor to ceiling definitely isn't even approaching overkill. Generally, that's a minimum recommended coverage.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
GIK Acoustics Giveaway! Qualification Thread Sonnie Home Audio Acoustics 42 04-06-07 01:39 PM
GIK Acoustics Giveaway Comments and Questions Thread Sonnie Home Audio Acoustics 8 03-31-07 11:48 PM
GIK Acoustics Giveaway! Sonnie Forum Announcements | News 3 03-05-07 06:01 PM
My results - what do you think? lovingdvd REW Forum 5 01-31-07 04:41 PM
Any benefit of Bass Trappings not in corners? steve shisler Home Audio Acoustics 15 01-03-07 03:12 PM
Mach 5 Audio
