| Home Audio Acoustics Looking for advice on my room...Discuss Looking for advice on my room... in the Home Theater Installation and Systems forum; Looking for advice on my room... ok, so I've got the pics of my strange nearly "cornerless" room... The only corner I don't have a pic ... |
| | #1 (Link) | |||
| Re: Bass traps or EQ ok, so I've got the pics of my strange nearly "cornerless" room... The only corner I don't have a pic of is the front L which has a double-door on it (the entrance to the HT room)... Help with bass traps most appreciated! I've really learned a lot from another thread here and wonder how this tech could apply best in my room--especially how I might use/alter corner traps for best bass response. Thanks Phil Dali Mentor 8/Vokal/Ikon Phantom 5.1; SVS pb13 Ultra; Sherbourn 7/2100A bridged 3 channels for 400+ watts to L/C/R & Onkyo 875 pre-pro & surround amp = Audio Heaven! ![]() Now about that projector... | |||
| | #2 (Link) | |||
| Re: Bass traps or EQ Some corner wedge traps could work really well in that room. GIK Acoustics has their Tri-Traps, and you could easily (if you're handy with tools) build a frame and cut the right kind of fiberglass into triangles and stack them. The corner behind the sub would be a good spot to treat with a floor-to-ceiling "pillar" wedge. Cover it in white fabric to match the walls and it will blend in. The corner behind the couch, where that little pine tree is sitting, would be another spot for a corner trap, maybe half-height to the top edge of the couch. And the scale could be off, but from the picture it looks like your mains are pretty far apart. Did you follow the manufacturer's guidelines for placement? Did you experiment to find where they produce a strong center image between the speakers, so you can "see" a person speaking or singing directly between them? Anyway, if you experimented and that's where they produce the best imaging, that's great. All speakers are different, and you have a wide room too. ![]() My HT Gallery (Updated pics of my setup and room treatments) My REW measurements with bass traps and BFD eq | |||
| | #5 (Link) | |||
| Re: Bass traps or EQ Hey CyberBri, Thanks for the input on the placement of the bass traps... Now to test the WAF waters! As for the Front Speaker placements in my room, they probably are too wide actually, especially since I moved my sectional seating up 6". I'll check into that this weekend and see. If I remember right the mains should be equi-distant between themselves and the seating right? Thanks, Phil Dali Mentor 8/Vokal/Ikon Phantom 5.1; SVS pb13 Ultra; Sherbourn 7/2100A bridged 3 channels for 400+ watts to L/C/R & Onkyo 875 pre-pro & surround amp = Audio Heaven! ![]() Now about that projector... | |||
| | #6 (Link) | |||
| Hey Ethan, What would a ceiling/wall corner treatment look like? Thanks so much for the help! Phil Dali Mentor 8/Vokal/Ikon Phantom 5.1; SVS pb13 Ultra; Sherbourn 7/2100A bridged 3 channels for 400+ watts to L/C/R & Onkyo 875 pre-pro & surround amp = Audio Heaven! ![]() Now about that projector... | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Dual Subs advice ??? | Alaric | REW Forum | 40 | 06-02-07 06:04 AM |
| In need of a little acoustical advice. Room layout included. | George | Home Audio Acoustics | 33 | 02-19-07 02:18 PM |
| Generic Advice on Accoustics | JCD | Home Audio Acoustics | 23 | 10-27-06 04:50 AM |
| Need Sound Design Advice | Sthrndream | Home Theater Design and Construction | 10 | 09-25-06 01:06 PM |
| Speaker Buying Advice | JCD | Home Audio Speakers | 2 | 08-29-06 02:04 PM |
