Room and Cabin Gain - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Room and Cabin Gain
Discuss Room and Cabin Gain in the Home Theater Installation and Systems forum; Room and Cabin Gain What is it?...
GIK Acoustics
Old 02-15-07, 11:10 AM   #1 (Link)
Alias: Jay
Loc: Western Wisconsin
jackfish's Avatar
User: #5100
Since: Dec 2006
jackfish is offline
Room and Cabin Gain
What is it?
Old 02-15-07, 03:11 PM   #2 (Link)
Alias: Ethan Winer
Loc: New Milford, CT, USA
Ethan Winer's Avatar
User: #1679
Ethan Winer is offline
Lightbulb Re: Room and Cabin Gain
jackfish wrote: View Post
What is it?
Room gain is simply a peak (increase) in the frequency response. All rooms resonate at some frequencies, and wherever there's a resonance there's a corresponding increase in the volume level. (There's also an unnaturally extended decay time.) These peaks are typical 3 to 6 dB, but in a cube room they could theoretically be as high as 18 dB at some locations in the room.
--Ethan
RealTraps
Old 02-15-07, 04:45 PM   #3 (Link)
Loc: Lower Alabama
Glad to see you posted this Jay...
Generally isn't the room gain noticed more when the speaker is closer to a boundary such as a wall? For instance, subwoofer response will generate more room gain in a corner than in the middle of the room.
Old 02-15-07, 06:12 PM   #4 (Link)
Alias: Jay
jackfish's Avatar
User: #5100
Since: Dec 2006
jackfish is offline
My understanding is that low frequencies are harder to deal with than those above about 200 Hz. Simple room treatments can deal with mid and high frequencies whereas low frequencies may require more sensitive speaker and listener placement.
Old 02-16-07, 03:13 PM   #5 (Link)
Alias: Ethan Winer
User: #1679
Sonnie wrote: View Post
Yes, exactly.
Also:
> My understanding is that low frequencies are harder to deal with than those above about 200 Hz. Simple room treatments can deal with mid and high frequencies whereas low frequencies may require more sensitive speaker and listener placement. <
Bass traps can do a good job down to 50 or 60 Hz if you have enough of them. Below that you could use EQ to reduce the last peak or two a bit, but I'd never try to EQ a null, nor would I use EQ much above 60 Hz.
--Ethan
RealTraps
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
Calculating Room Modes - Odd Shaped Room Bob in St. Louis Home Theater Design and Construction 25 02-20-07 12:15 PM
DSP1124P gain? M-Audio Uno gotcha blekenbleu BFD Forum 3 01-21-07 12:21 PM
Porting an IB... looking for room gain... Chrisbee DIY Subwoofers - Infinite Baffle 7 01-14-07 05:26 AM
Any way to limit gain to +/-10.0 dB? maxcooper REW Forum 17 12-16-06 04:08 PM
Mach 5 Audio
