| Home Audio Acoustics DIY Corner trapDiscuss DIY Corner trap in the Home Theater Installation and Systems forum; DIY Corner trap I would like to seek some opinions. I am getting ready to build some traps. For 2 corners what I ... |
| | #1 (Link) | |||
| DIY Corner trap I would like to seek some opinions. I am getting ready to build some traps. For 2 corners what I was going to do was use 703 at 6" deep 24' wide. My question is, since the ceiling is 8 feet high should I make the trap 8 feet also or around 7 feet since the back of the trap will be exposed? I have attached a little drawing to show how it will be away from the wall. | |||
| | #2 (Link) | |||
| Re: DIY Corner trap I'd go floor to ceiling. Also, by the time you buy enough 703 to do 6" straddling the corner, you can actually build solid triangular chunk style absorbers of the same height from the same amount of material with the same 24" face size. They'll stick out less in your room and perform better down in the really deep bass. Bryan | |||
| | #3 (Link) | |||
| Re: DIY Corner trap Bryan, Thanks for your reply. I am a little confused on a few things you mention. To do what I was planning on will take 6 pieces of 703 per corner (I got 288 square feet of 703 plain 2” thick for under 275$ delivered). I don’t see how I could make a solid triangular chunk design with that amount (6 pieces) or how they would stick out less. My thought was to cut the 703 at the corners to a 45 degree angle so by the time I got to the inner most piece it would be 20 to 18 inches wide with 45 degree corners so everything would fit flush to the wall (hope that makes sense). Also, wouldn’t the trap benefit from having to side exposed instead of just one? Thanks. | |||
| | #4 (Link) | |||
| Re: DIY Corner trap When you cut triangles to put in the corner, each panel yields 8 triangles so at 2" thick per panel, that's 16" height per panel. Six panels will give you 96" of coverage (8 ft.). Also, they would fit right up against the walls in the corner. I don't believe that there would be any benefit to leaving a space with chunks but I'm sure someone will correct me if I'm wrong. Brian is correct that the chunks would perform better than 6" of panels. Bob "There is always hope, even if it is just a fool's hope." | |||
| | #6 (Link) | |||
| Re: DIY Corner trap No problem. This URL is a good reference and has a cutting pattern for the 703: http://forum.studiotips.com/viewtopic.php?t=535 Bob "There is always hope, even if it is just a fool's hope." | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| DIY Bass Trap....Will it Work ? | Marks57 | Home Audio Acoustics | 27 | 04-17-08 01:07 PM |
| Another corner trap question... | chas | Home Audio Acoustics | 32 | 02-14-07 02:19 PM |
| Trap Questions | Bob_99 | Home Audio Acoustics | 3 | 01-24-07 06:30 AM |
| Corner Trap Placement | Josuah | Home Audio Acoustics | 6 | 01-16-07 10:20 PM |
| Finally Corner Loaded | Ayreonaut | Home Audio Subwoofers | 13 | 09-07-06 09:08 PM |
