Go Back   Home Theater Forum - Home Theater Systems - HomeTheaterShack.com > Home Theater Installation | Systems > Home Audio Acoustics
My DIY treatments  Discuss My DIY treatments in the Home Theater Installation | Systems forum; My DIY treatments I just wanted to post a few pictures of on DIY panels. I am building three to go across corners, ...
Views: 1372 - Replies: 19
Old 05-13-07, 07:59 AM   #1
Alias: James
User: #3519
Since: Oct 2006
  exojam is offline
My DIY treatments
I just wanted to post a few pictures of on DIY panels. I am building three to go across corners, one "standard" 2'x4'x4" panel and two eight foot corner traps. I have lined the back of these with polly fill fabric since they will not be seen and will save on some fabric. Still trying to think of how I will mount them to the wall. I will post some more picturess when the fabric is applied.
Old 05-13-07, 08:09 AM   #2
Shack Moderator
Alias: Bryan Pape
bpape's Avatar
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is online now
Re: My DIY treatments
Looking good. Just a couple of suggestions:
You might want to consdier some cross bracing on the tall corner panels so when you stretch the cloth tight the frames don't bow in.
On the wall panels, if you can get the poly inside the frame (assuming the frame is thicker than the absorbtion), you can use smal hooks inside the frame facing each other and just use picture hanging wire. Or, if you have enough room, you can cut a little slot in the top of the frame (inside) and use a hook on the wall to slip in the slot.
Good luck.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 05-13-07, 10:09 AM   #3
Alias: James
User: #3519
Since: Oct 2006
  exojam is offline
Bryan,
Thanks for the reply. I did not even think about the cross bracing. I will get some in there before adding the fabric and also pick up some picture wire.
Old 05-13-07, 01:23 PM   #4
Alias: chas
Loc: Minnesota
User: #6091
Since: Jan 2007
  chas is offline
Looks good. What kind of lumber did you use for the corner trap frames?
Old 05-13-07, 03:05 PM   #5
Alias: James
User: #3519
Since: Oct 2006
  exojam is offline
I believe it is just pine. To be honest I did not look for a specifc type, I just went to Home Depost and grabbed a 6 1"x11"x8'. I than had a friend with a table saw rip it to the width I needed.
Old 05-14-07, 08:40 PM   #6
Alias: James
User: #3519
Since: Oct 2006
  exojam is offline
Well, here is my first finsihed panel. I dont' think it looks to shabby. This is not the final resting place for it, just put it here to take a picture.
Old 05-15-07, 06:12 AM   #7
Shack Moderator
Alias: Bryan Pape
bpape's Avatar
User: #2579
Since: Sep 2006
  bpape is online now
Looks good. Looking forwared to pics of everything up and mounted and your impressions of the changes in the room's performance.
Bryan
Bryan Pape
GIK Acoustics
Old 05-15-07, 07:59 AM   #8
Alias: chas
Loc: Minnesota
User: #6091
Since: Jan 2007
  chas is offline
Not shabby at all James - looks really good. What kind of fabric did you use?
Old 05-15-07, 09:34 AM   #9
Alias: James
User: #3519
Since: Oct 2006
  exojam is offline
It is the burlab (Mocha) from ATS Acoustics.
Old 05-15-07, 10:31 AM   #10
Alias: chas
Loc: Minnesota
User: #6091
Since: Jan 2007
  chas is offline
I have some burlap from them as well. It seems to be decent quality burlap - much better than the I was looking at at Joanne's.
« Home Theater Shack > Home Theater Installation | Systems > Home Audio Acoustics »
Bookmark and Share
Dish Network
