| Home Audio Acoustics Pics of room - where to start with acousticsDiscuss Pics of room - where to start with acoustics in the Home Theater Installation and Systems forum; Pics of room - where to start with acoustics Will 8# MW work for the Panels since this is what I am starting with - This is my plan ... |
| | #26 (Link) | |||
| Re: Pics of room - where to start with acoustics Will 8# MW work for the Panels since this is what I am starting with - This is my plan for the front. Panel left/right of screen and one below behind center channel & left/right as 1st reflection points. back will be like pic attatched. | |||
| | #27 (Link) | |||
| Re: Pics of room - where to start with acoustics If you're DIY'ing, do teh entire front wall. 8lb will be fine for this and the back wall. For the sides, I'd personally prefer something less dense since you're going to have some reflections with pretty shallow angles of incidence dnt the denser material can allow it to skip off sometimes. Bryan | |||
| | #28 (Link) | |||
| Re: Pics of room - where to start with acoustics For the front walls by the two main speakers - is a acoustic panel behind each speaker better or my other thought for now is make two panels and stack them on top of each other and angle them in the corner. On the building process is there a better way to build them - one without a backing and one with. http://swbg1.tripod.com/diy_acoustic_panels.htm http://www.angelfire.com/sports/RCca...tic_panels.htm | |||
| | #30 (Link) | |||
| Re: Pics of room - where to start with acoustics It is exactly 11 1/2" from the outside of my screen to the side walls. So if I made panels the MW would be 9" wide if I used 3/4" wide wood as this gives me 1/2" of space on each side of the panel - similiar to the diagram of the front wall above. I cut out a piece of cardboard that was 10 1/2" wide by 4' tall. Now if I use a acoustic panel on the front wall and my speaker has a high port and low port on the back side do I want to lower the panel as low as the lowest port on that speaker? | |||
| | #31 (Link) | |||
| Re: Pics of room - where to start with acoustics What type of fabric do most people use if they buy locally? Burlap Is there anything else that is usable? With the wood frame what is the best size/type of wood to use? | |||
| | #32 (Link) | ||||
| Re: Pics of room - where to start with acoustics Quote:
Fortunitly mine are in a very dark room and they are black (dark color also works) and nobody would be able to tell. You want to use strong wood that is light and easy to work with. For the wood, maybe someone would comment on the different variations in the different price ranges but it is not set in stone what is best.High Speed Cable/Dial Up User - Remodeling/Designing/Building Last edited by thewire; 04-30-08 at 08:25 PM. | ||||
| | #34 (Link) | |||
| Re: Pics of room - where to start with acoustics Here is a link some examples of muslin. http://tinyurl.com/3nrqu3 | |||
| | #38 (Link) | |||
| Re: Pics of room - where to start with acoustics Just some cheaper fabric I found at JoAnne Fabrics. $3.99 a yard though I did get some of it on sale. I didn't buy it all at once as I wasn't sure on how it was going to stretch over the wood. It says Black Scroll 3680899 Last edited by cburbs; 05-15-08 at 05:55 PM. | |||
| | #41 (Link) | |||
| Re: Pics of room - where to start with acoustics I can look at my receipt. I basically looked over in a section where they had items seperated by colors and looked at the black cloth with designs on it. I didn't want anything too busy that showed it and this is but it doesn't show it like the rest of them. Some had skulls, circles but where big and stood out - more black on white. | |||
| | #46 (Link) | ||||
![]() Later when you build the other you can move it. ![]() | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Need some help with room acoustics | Tobias | Home Audio Acoustics | 7 | 04-26-07 12:13 PM |
