Pics of room - where to start with acoustics - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Discuss Pics of room - where to start with acoustics in the Home Theater Installation and Systems forum; Pics of room - where to start with acoustics I am looking at the DIY Route but not sure where to start. I would like to start off with ...
GIK Acoustics
Old 06-06-07, 07:29 AM   #1 (Link)
Alias: chad
User: #7756
Since: Mar 2007
cburbs is offline
I am looking at the DIY Route but not sure where to start. I would like to start off with say Owens Corning 703 - 2 inch case of 6. So where would you place 6 panels to start off with.....?
Old 06-06-07, 08:42 AM   #2 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Re: Pics of room - where to start with acoustics
With just 6 pieces, you're going to make some compromises. It's not enough to do any kind of bottom end control so it will be mostly for reflection purposes.
You need to hit the side wall reflection points - most likely one panel will be on the door on the right and one opposite it. I'd also take down the poster directly opposite the equipment rack as you'll get nasty slap and pinging in that little area off to the right side.
I'd likely use the rest to do as much of the front wall as you can. You want the front wall basically totally dead.
Next thing to consider is making some smaller chunk style triangular absorbers floor to ceiling in the front corners to help with overall bass control and SBIR control since the speakers are basically right in the corners.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 06-06-07, 08:47 AM   #3 (Link)
Alias: Wade
Loc: Minot, North Dakota
adogand6kids's Avatar
User: #1793
adogand6kids is offline
Chad,
In response to your question about where to place 6 panels, I will give you two different answers. The answers differ based on what your primary desire is for your acoustic treatment.
Option One: Absorbing First Reflections
If this is your primary desire, then place 1 panel each on the left and right side walls at the first reflection points (you may need to move some posters). To know the correct location, follow the instructions given here: http://www.realtraps.com/rfz.htm . Next, place 1 panel each behind your left and right main speakers (or you could place 2 panels on the theater's rear wall). Finally, place two panels on the ceiling to absorb first reflections there.
Option Two: Bass Trapping
If your main desire is to absorb low frequencies then use your panels to make corner bass traps. I am guessing that your ceiling height is just under 7 feet. Use 3 panels in each to stradel your front corners from floor to ceiling. Double up the panels to make them 4 inches thick. Let me add a suggestion that you consider buying more panels and making more than just two traps if you do want to bass trap your room. Ideally, you would place traps in the two front corners, the front corner next to your built in equipment rack, the rear corner where the standing lamp is currently located and maybe along the wall/ceiling corner under the sofitt.
Six panels is not enough to do both, and looking at your room, I am not sure it would be enough to effectivley bass trap your room. I would suggest that if you can only go with 6 panels, you use them to absorb first reflections. Then, as soon as you are able, start getting more panels and add bass traps. There are a ton of examples of DIY absorbers and bass traps on the home audio acoustics page at this forum. Look there for ideas. Hope this helps.
Old 06-06-07, 11:54 AM   #4 (Link)
Alias: chad
User: #7756
Since: Mar 2007
cburbs is offline
So for corner bass traps is it better to use chuncks than to just put a panel in - http://forum.studiotips.com/viewtopic.php?t=535 similiar to this.
Since I don't have tons of room in the corner would it still pay off up front?
Would I benefit by putting say a 4" thick acoustic panel on the door that leads into the room. Look at the 1st pic - brown door?
Old 06-06-07, 08:30 PM   #5 (Link)
Alias: chad
User: #7756
Since: Mar 2007
cburbs is offline
This looks like some good info as well - http://www.runet.edu/~shelm/acoustics/bass-traps.html
Old 06-06-07, 08:52 PM   #6 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
I'd make the chunks - but at half the size since you don't have much space to the sides of the screen. That will let you get 16 triangles that are 12x12x17 out of each piece. 16 pcs at 2" thick each gives you a 32" high solid chunk from each 2'x4'x2" piece.
I'd agree that another box of 6 is in order to do the room properly.
Bryan
Bryan Pape
GIK Acoustics
Old 06-07-07, 12:58 PM   #7 (Link)
Alias: chad
User: #7756
Since: Mar 2007
cburbs is offline
Brian,
Is it best to go from floor to ceiling?
12*12*17 is too wide for me up front. If I do say 8" does it even pay?
Is it possible to go smaller?
Old 06-07-07, 01:25 PM   #8 (Link)
Alias: Wade
User: #1793
The chunks will give you absorption to a lower frequency (I couldn't tell you how low). The panels take less fiberglass and are a bit less work. So, the answer depends on how much money and time you have to invest.
I think I know what you are asking here - and Yes, corner traps up front behind your mains will help. You may need to move your mains forward into the room a bit.
Do you want that 4" acoustic panel to be a bass trap? If so then the answer is no - it won't be a very effective bass trap. Do you want that 4" panel to absorb sound coming from the front speakers so it doesn't bounce back - then the answer is yes, but you don't need the panel to be 4" thick. You would do better to use 2 panels each 2" thick.
Old 06-08-07, 06:32 AM   #9 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Do what you can. Anything is better than nothing. If you only have 8", then I'd likely make the best use I can and make an 8" x 6" rectangular absorber floor to ceiling. You might also consdier building some false soffiting around the upper perimeter of the room where possible. Again, even if it's only say 6"x6", that's better than nothing. You just don't have a lot of space left over for broadband treatment.
Bryan
Bryan Pape
GIK Acoustics
Old 04-13-08, 08:25 PM   #10 (Link)
Alias: chad
User: #7756
Since: Mar 2007
cburbs is offline
So is the 703 that much better to buy over the other two listed here?
http://www.atsacoustics.com/cat--Fib...ards--106.html
I should be able to actually start on this finally - Again it will be started off doing 6 panels. So any suggestions added to the above would be great.
Old 04-14-08, 06:17 AM   #11 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
The 60 density is OK if you're going to chunk it up for bass absorbers. I just don't care to work with it as it's a PITA to cut. It can be very effective acoustically though.
Bryan
Bryan Pape
GIK Acoustics
Old 04-14-08, 09:16 AM   #12 (Link)
Alias: chad
User: #7756
Since: Mar 2007
cburbs is offline
Bryan - I will be building some panels for my first round -
So here is my idea - please let me know your thoughts.
Front wall behind speaker - One panel behind the front two speakers. So this is really one panel cut in half since I only have like 11" from screen to corner.
Two panels at First reflection point - front right door and straight across from there.
This leaves 3 panels left - where would you suggest to put them?
Old 04-14-08, 09:35 AM   #13 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Ideally, you'd cover the entire front wall - thicker in corners.
I'd then start thinking about some thicker panels centered on the rear wall to catch nulls coming off there and opposite the screen.
Bryan
Bryan Pape
GIK Acoustics
Old 04-14-08, 10:51 AM   #14 (Link)
Alias: chad
User: #7756
Since: Mar 2007
cburbs is offline
So something like this -
Old 04-14-08, 11:09 AM   #15 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
That'd work.
Bryan
Bryan Pape
GIK Acoustics
Old 04-14-08, 02:07 PM   #16 (Link)
Alias: chad
User: #7756
Since: Mar 2007
cburbs is offline
How do you figure out how high to hang them? Like say the 3 on the back wall ?
The ones behind the front speakers?
Old 04-14-08, 02:14 PM   #17 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Get the top of the panel about 6' off the floor. The idea is to get a bit up high but primarily cover behind seated head height.
Bryan
Bryan Pape
GIK Acoustics
Old 04-14-08, 04:44 PM   #18 (Link)
Alias: chad
User: #7756
Since: Mar 2007
cburbs is offline
What about behind the front speakers and first reflection points - how high on these?
Old 04-14-08, 05:34 PM   #19 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Side reflections about the same. Behind the speakers depends on the situation - play with it a little and see what works best for you. Just sit them on some books or a milk crate or chair to change heights and see.
Bryan
Bryan Pape
GIK Acoustics
Old 04-16-08, 06:23 AM   #20 (Link)
Alias: chad
User: #7756
Since: Mar 2007
cburbs is offline
In the corners what is the big difference if you do wedges floor to ceiling or make a panel floor to ceiling? Yes I know the wedges will be denser.
Old 04-16-08, 08:05 AM   #21 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Wedges won't necessarily be denser if made from the same materail. What they will be is thicker which puts more of a wave in the absorbtion longer and gets closer to the 1/4 wavelength optimum on lower (longer) frequencies. In essence, they'll just reach down deeper more effectively.
By the time you get enough material to do a 6" thick panel straddling, you can make a chunk style absorber of the same width and height that will reach deeper and take up less space in the room. The panel would have it's rear face hitting the walls at the same distance that the front of the wedge would be.
Bryan
Bryan Pape
GIK Acoustics
Old 04-16-08, 08:12 AM   #22 (Link)
Alias: chad
User: #7756
Since: Mar 2007
cburbs is offline
Ok that makes sense - So you are saying this is the better way to go -
http://www.hometheatershack.com/foru...-finished.html
Old 04-16-08, 08:26 AM   #23 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Yes. That will take the same amount of acoustical core as a 6" thick panel straddling the corner with air behind it.
Bryan
Bryan Pape
GIK Acoustics
Old 04-22-08, 04:36 PM   #24 (Link)
Alias: chad
User: #7756
Since: Mar 2007
cburbs is offline
Ok so locally I can get the 2" JM814 or they have a 2" Mineral Wool that is density of 8 pounds per cubic foot. Since the MW is at a good price is there any issue with using it?
Old 04-22-08, 04:41 PM   #25 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
It'll be just fine for the corner absorbers.
Bryan
Bryan Pape
GIK Acoustics
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
