Baffle problem - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Baffle problem
Discuss Baffle problem in the Home Theater Installation and Systems forum; Baffle problem It would be nice to determine the solution for a common problem of baffle. I am not interested in watching ...
GIK Acoustics
Old 07-27-07, 10:39 AM   #1 (Link)
New Member
Alias: Jesus
Loc: Zagreb, Croatia, Europe
User: #1875
Since: Aug 2006
Mario Petrinovich is offline
Baffle problem
It would be nice to determine the solution for a common problem of baffle. I am not interested in watching movies, but never-the-less I do have LCD screen between my speakers. Since LCD screen can be close to speakers in small rooms, LCD screen can act as speaker baffle. In the same time the position of LCD is very close to where you would like to place some absorption, so that it helps low frequencies. And this all is in place of each other. Now, what to do, should I push LCD screen all the way to the wall, or should I put some absorption there, and place LCD closer to speakers?
On pictures you can see those three solutions how they look in my room. The absorption is 4" of 703 spaced 4" from the wall. Now, should I leave gap in that absorption, and place LCD in that gap; should I attach 4" of absorption directly to the wall (ie, without 4" of air between wall and absorption); or should I cover whole wall with absorption, and put LCD screen in-front of this? TIA. -- Mario Petrinovich
Old 07-27-07, 07:24 PM   #2 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
Re: Baffle problem
As a purely neophyte in such things, I'll still address a couple of the issues that were brought up:
  1. I would NOT use the LCD to extend the baffle of your speakers -- I think you were thinking this might be a good thing. It probably isn't as the crossover built in to your speakers assumes a baffle width (for BSC) the width of your speaker as is.
  2. I'd think that putting OC703 behind the LCD won't help much if the LCD screen is too close to the wall like you've indicated. Even if you were just trying to tame the bass, I think too much would be reflected off the LCD screen. I could be wrong of course.
  3. Id be afraid of covering the entire wall. Too much of anything is usually a bad thing. I think this may be overkill and be detrimental to the overall sound of the room rather than helping. I've been a well treated room and I've been in an overtreated room. The first was a revelation. The second was depressing.
Anyway, hopefully the true masters will chime in and offer further help and clear up any misinformation I'm spouting.
JCD
Old 07-28-07, 12:05 PM   #3 (Link)
New Member
Alias: Jesus
User: #1875
Since: Aug 2006
Re: Baffle problem
JCD wrote: View Post
JCD
Thanks for your response.
Here are my comments.
1. It is not my intention to extend the baffle of my speaker with the LCD. It is just that LCD is positioned there, and I don't know whether should I put it in front of absorption, or directly to the wall. I am not sure which solution would provide better sound.
2. Well, I really don't know what to do. I've read about some solutions with rigid surface backed up with some absorption, that worked alright. I believe that this is similar case.
3. Yes, I know. The example above was just for examplatery purpose. I don't know how much absorption I will put on this wall. But this doesn't matter, in this case, anyway. This is a different thing. Since LCD will be in-front of absorption, so this will be strictly, like, low frequencies absorber (or something), which you never have enough of. The dilemma is whether I will create more problems than solve ones, by putting LCD 20 cm closer to speakers. -- Mario Petrinovich
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
Open Baffle Bob in St. Louis DIY Speakers 165 01-03-08 03:55 PM
Open baffle center channel BoomieMCT DIY Speakers 7 06-21-07 07:07 AM
Baffle step considerations... aceinc DIY Speakers 2 05-27-07 02:11 AM
Trouble with Baffle Step Compensation Circuits BoomieMCT DIY Speakers 1 04-13-07 07:22 PM
Fiberglass Open Baffle Bob in St. Louis DIY Speakers 12 04-02-07 05:47 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195
