Window Treatment - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Window Treatment
Discuss Window Treatment in the Home Theater Installation and Systems forum; Window Treatment Since I don't have the luxury of a dedicated home theater and my HT coexists with our living room, I ...
GIK Acoustics
Old 08-06-07, 08:49 AM   #1 (Link)
Alias: Bob_99
Loc: New Hampshire
Bob_99's Avatar
User: #460
Bob_99 is online now
Window Treatment
Since I don't have the luxury of a dedicated home theater and my HT coexists with our living room, I have to deal with windows. I have procrastinated treating the windows while I treated the rest of the room but the time has come to do something. I know that the best treatment would probably be rigid fiberglass plugs but I don't think that would be an option, not only because of the WAF but it would be annoying to put them in and take them out every time I wanted to watch something. Living in a darkened space is not an option. In any case, as far as I can tell from reading and previous questions, I guess the best that I can do is probably wooden blinds so my questions are:
Would there be a difference between one inch and two inch slats?
Would there be a big difference between type of wood and or synthetic material?
Any better solution that someone can think of?
Thanks for any information/thoughts or comments.
Bob
"There is always hope, even if it is just a fool's hope."
Old 08-06-07, 09:19 AM   #2 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Re: Window Treatment
Where are they in relation to the room layout? Side wall? Back wall?
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 08-06-07, 09:25 AM   #3 (Link)
Alias: Bob_99
Loc: New Hampshire
Bob_99's Avatar
User: #460
Bryan,
Two each on the side walls and one on the front wall. The one on the front wall is to the left; very close to the left wall.
Bob
Old 08-06-07, 09:30 AM   #4 (Link)
Alias: AC
Loc: WICHITA, KS
ACGREEN's Avatar
User: #6917
ACGREEN is online now
I have the same problem. I have pre-wired for remote blinds or drapes. Drapes would be the best as they are going to block the most light. But if you are married and your wife has any decorating sense, she will not allow drapes. (Yes, marriage is how I expect you know where to be) So, you me be left to choose form different blinds. There are many styles that each have advantages.
Home Decorators have many different options and you can view them here.
Old 08-06-07, 10:09 AM   #5 (Link)
Alias: Bob_99
Loc: New Hampshire
Bob_99's Avatar
User: #460
It definitely can have it's moments .....
Old 08-06-07, 02:17 PM   #6 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
Bob_99 wrote: View Post
... Two each on the side walls and one on the front wall. The one on the front wall is to the left; very close to the left wall.
That's a lot of windows ... I was thinking maybe one or two
In my case there's only one windows (in the back of the room), so what I did is to build a pair of sliding door (like the closets) ... I used 1/2 MDF and some accoustical carpet (same that I used on walls) ... I open or close the door as need it (here is the pictures)
Old 08-06-07, 02:23 PM   #7 (Link)
Alias: Bob_99
Loc: New Hampshire
Bob_99's Avatar
User: #460
David,
Nice setup! I don't even approach anything like that and my windows are the regular type (29"Wx51"H). That's a good approach with the sliding doors for that kind of window. Nice!
Bob
Old 08-06-07, 02:44 PM   #8 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
David, Nice setup! I don't even approach anything like that and my windows are the regular type (29"Wx51"H). That's a good approach with the sliding doors for that kind of window. Nice! Bob
Thank You, Bob
When I was remodeling the room I kept about the light from the window ... and one day suddenly ... this was the result ... and I'm very, very happy because I solved the light and sound reflection problem ....
Old 08-07-07, 06:39 AM   #9 (Link)
Alias: Bob_99
Loc: New Hampshire
Bob_99's Avatar
User: #460
Bryan? Did you have anything to add?
Thanks.
Bob
Old 08-07-07, 07:31 AM   #10 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Sorry - craziness right now and didn't get a notification until just now.
For those locations, heavy curtains is what I'd do. You'll need absorbtion in those places anyway.
Bryan
Bryan Pape
GIK Acoustics
Old 10-27-07, 03:27 PM   #11 (Link)
Bronze Supporter
Alias: FJ
Loc: Marysville, WA
User: #11951
Since: Sep 2007
Scuba Diver is offline
Have you concidered using a sound blanket. They work as darkeners and provide some sound proofing.
A little creativity and I am sure the could be made functional.
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
Room treatment advice exojam Home Audio Acoustics 7 04-10-07 08:55 PM
Glass window for projector? basementjack Home Theater Design and Construction 9 03-27-07 05:27 PM
Room Treatment Suggestions Otto Home Audio Acoustics 6 02-14-07 07:13 PM
why need acoustic treatment? lienly Home Audio Acoustics 2 02-13-07 08:27 PM
Acoustic Treatment Project jagman Home Audio Acoustics 17 10-08-06 05:20 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
