Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
OC705 vs. OC703
Discuss OC705 vs. OC703 in the Home Theater Installation and Systems forum; OC705 vs. OC703 I often hear that OC705 is better for building bass traps. However every time I see a comparison of absorption ...
GIK Acoustics
Views: 1351 - Replies: 4
Old 08-06-07, 03:43 PM   #1
Alias: Boom
BoomieMCT's Avatar
Loc: Fairfax, Va
User: #4757
Since: Dec 2006
  BoomieMCT is offline
OC705 vs. OC703
I often hear that OC705 is better for building bass traps. However every time I see a comparison of absorption characteristics OC703 seems to absorb more @ 125 Hz.
Here is an example, ATS comparo
What am I missing here?
Old 08-07-07, 06:44 AM   #2
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Re: OC705 vs. OC703
125Hz performance doesn't map directly to making a good bass trap. Unfortunately, you can't really do standardized tests at 40-50Hz.
The other thing that nobody addresses is thickness. If you're limited to 4", then 705 is a better choice. If you can go 6", then 703 will work just as well and will cost you less.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 08-07-07, 02:20 PM   #3
Alias: Ethan Winer
Ethan Winer's Avatar
Loc: New Milford, CT, USA
User: #1679
  Ethan Winer is offline
Lightbulb Re: OC705 vs. OC703
BoomieMCT wrote: View Post
See this:
www.ethanwiner.com/density.html
--Ethan
RealTraps
Old 12-10-08, 08:40 AM   #4
Alias: Matt
Loc: Virginia
User: #25945
Since: Sep 2008
  grn1969c10 is offline
Re: OC705 vs. OC703
Is it OK to resurrect a really old thread? There may be updated information available somewhere, but I'm chasing rabbit trails with the search feature right now.
http://www.ethanwiner.com/density.html
Ethan touts reducing the Q as a positive benefit. This spreads an effect across a wider frequency range. Wouldn't increasing the Q (giving a peak narrower bandwidth with steeper slope instead) make it easier to accurately target with a narrower parametric EQ filter?
Old 12-10-08, 09:18 AM   #5
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
Re: OC705 vs. OC703
If you want to do that, you have to start adding a membrane, calculating the specific resistance and flexibility of the membrane and a specific thickness of the 703/705, etc.
As an example:
Coefficients at 125, 250, 400, 1k, 2k, and 4k for various thicknesses and densities.
1"
703 FSK
0.18 0.75 0.58 0.72 0.62 0.35
705 FSK
0.27 0.66 0.33 0.66 0.51 0.41
2"
703 FSK
0.63 0.56 0.95 0.79 0.60 0.35
705 FSK
0.60 0.50 0.63 0.82 0.45 0.34
3"
703 FSK
0.84 0.88 0.86 0.71 0.52 0.26
705 FSK
0.66 0.46 0.47 0.40 0.52 0.31
Standard R-19 wall insulation ( around 1lb/cu ft density), paper faced. Paper facing the room
0.94 1.33 1.02 0.71 0.56 0.39
Some of those will actually show humps below the standardized 125hz band.
Bryan
Bryan Pape
GIK Acoustics
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
