| Home Audio Acoustics ETC GraphsDiscuss ETC Graphs in the Home Theater Installation and Systems forum; ETC Graphs Ethan or Bryan,
When looking at ETC data, what frequency range gives the best picture of what's happening (500Hz to ... |
| | #1 (Link) | |||
| ETC Graphs Ethan or Bryan, When looking at ETC data, what frequency range gives the best picture of what's happening (500Hz to 5000Hz)? Also, is it better to break it down into smaller ranges (1000Hz-2000Hz,2000Hz-3000Hz,etc.)? Thank you. Bob "There is always hope, even if it is just a fool's hope." | |||
| | #2 (Link) | ||||
| Quote:
--Ethan RealTraps | ||||
| | #3 (Link) | |||
| Re: ETC Graphs Ethan, I am looking for problems with early reflections but also just trying to understand more about acoustics and was wondering if this could be useful to determine how to treat first reflections. Here is what started me thinking about it: ![]() ![]() You can see that the reflection at about 2 ms is more pronounce when using a narrower bandwidth. I'm not sure if that's real or just a result of the method used in the software calculations. If it's real, would it be reasonable to say that I need something thicker at the first reflection point? Thanks again. Bob "There is always hope, even if it is just a fool's hope." Last edited by Bob_99; 08-20-07 at 06:45 AM. | |||
| | #5 (Link) | |||
| LOL, I was pretty busy all week. The first reflection that hits in the top graph is only a few dB below the primary sound, so that's a problem for sure. That it's 2 ms later means a path difference of about 2 feet. So that could be from a side wall if the speakers are close to the walls, or the floor, or both. I generally look at the full range to see it all in one graph. Regardless, if you treat the side walls and ceiling, and optionally the floor, at the usual places, those reflections should drop to less than 15 dB. --Ethan RealTraps | |||
| | #7 (Link) | |||
| Re: ETC Graphs The ETC graph can be tricky - you are always trading off frequency resolution for time resolution and this is the heisenberg principle and cannot be escaped. If you want lots of detail in time then you must use a wide frequency range. I like to look at individual driver radiation and have about 1 ms of resolution so for a two way speaker that has a crossover of 2.5 KHz I will choose a band of 1000 Hz - 2000 Hz for the mid/woofer and about 3000 - 4000 Hz for the tweeter. Notice that the bandwidth is the same in both cases = 1000 Hz. This gives me 1/1000 sec or 1 ms of resolution. If I want a detailed view of cabinet diffraction I know that most of it comes from the tweeter and I can use a wide band on the tweeter so a band of 3000 - 8000 Hz gives a resolution of 1 / (8000-3000) = 1/5000 = 0.2 ms. To accurately quantify a single reflection you need to use a wide enough band to isolate it from the others. The 1 ms band used in the above top graph isn't enough to really isolate that single 2 ms reflection. Try using a 5 KHz band in the tweeters operating range then you will see it clearly. Try 5 KHz - 10 KHz. RPlusD has a great manual (so people are telling me) and you can download and read it for free. The methods used in this manual are more evolved in terms of methods than most. Essentially RPlusD was created to apply better measurement techniques. It was a redesign of ETF from the bottom up. All ETF users get RPlusD free of charge (for ETF purchase after Sept 1 2000). The manual can be used as a guide for most audio measurement software in use today. | |||
| | #8 (Link) | |||
| Re: ETC Graphs The second graph posted above does isolate that reflection and give a true indication of its actual level. The resolution is 1/(20,000-15)= Very Small. So its a detailed look at time domain behaviour. I get a spelling error for "behaviour" and wonder why you Americans keep spelling everything wrong 8-) | |||
| | #9 (Link) | |||||
| Re: ETC Graphs Doug, It's great to see you posting on this forum and thank you for your response. Your answer is the information that I was looking for. Quote:
Bob "There is always hope, even if it is just a fool's hope." | |||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Some graphs, any suggestions | spamula9 | REW Forum | 13 | 03-14-07 10:43 PM |
| my graphs | frockc | REW Forum | 3 | 01-21-07 08:59 PM |
| My graphs | Hakka | REW Forum | 11 | 11-11-06 06:03 PM |
| First Graphs... | rolyasm | REW Forum | 48 | 07-29-06 07:40 PM |
