| Home Audio Acoustics DIY bass traps and absorbersDiscuss DIY bass traps and absorbers in the Home Theater Installation and Systems forum; DIY bass traps and absorbers I was shown and found some info on creating your own absorbers and bass traps using OC 703 rigid fiber.
| | #1 (Link) | |||
| DIY bass traps and absorbers I was shown and found some info on creating your own absorbers and bass traps using OC 703 rigid fiber. They recommend using 2 layers to get 4". I was wondering if there'd be any loss of effectiveness or gain in effectiveness if I use 13" R-38. Would that extend the absorption to lower frequencies? Would these be good for putting in the corner for low frequency absorption? I assume if I space them from the wall it allow double absorption of extended freq's from the direct sound and first reflections. I need a cheap and effective full freq. treatment. Any advice is welcome. | |||
| | #2 (Link) | |||
| Re: DIY bass traps and absorbers The thicker the better in areas which are going to be asked to do bass absorbtion. It's about a breakeven at approx 8" of thickness vs OC703 with a slight loss from about 60Hz down. On the walls, there's no way I'd put up something 13" thick and compressing it gets you right back to a thinner material. In those cases (for reflections on the side walls), 2" OC703 or 2" 3lb Acoustical Cotton are the best options. Bryan | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Bass traps | Fincave | Home Audio Acoustics | 55 | 06-01-08 09:00 AM |
| Generic Foam bass traps | SleepingRobot | Home Audio Acoustics | 6 | 05-14-07 07:15 PM |
| Bass traps or EQ | F1 fan | Home Audio Acoustics | 78 | 04-26-07 07:36 PM |
| Hard or Soft Covering for DIY Bass Traps | adogand6kids | Home Audio Acoustics | 23 | 02-28-07 05:47 AM |
| Bass Traps with style? | Boaphile | Home Audio Acoustics | 48 | 02-06-07 02:27 PM |
