Tackling the 20hz-100hz waterfall - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 3 Old 07-24-13, 01:44 AM Thread Starter
Arvtechman's Avatar
Austin
I realize I probably should have posted here originally considering my goals. However I am new to home theater shack and REW as well. I won't retype everything here and probably will need my original post moved here. To summarize I have taken measurements with REW and I'm looking to determine the best approach for using sound absorption and/or diffusion panels if needed, but after the REW results I may need a lot of bass trapping...
Original post here:
http://www.hometheatershack.com/foru...cks-setup.html
Pioneer SC-75 (Bi-Amp Fronts)
Onkyo M282 (Bi-Amp Center)
Sony BluRay BDP-S790
Bowers and Wilkins CM8
Bowers and Wilkins CMC2
Bowers and Wilkins DS3 (4)
Definitive ProSub1000
Polk PSW-10
Arvtechman is offline
post #2 of 3 Old 07-24-13, 05:59 AM
hjones4841's Avatar
Silly Girl!
Re: Tackling the 20hz-100hz waterfall
Bass traps do make an amazing amount of difference. However, it is almost impossible to make much difference below about 50-60Hz. The wavelength of the sound below there is very large and very difficult to trap - think a foot or so of rockwool or Corning 703 to make even a small dent.
I got into trapping about 3 years ago for my 12x20x8ft HT. I ended up with 5 GIK Monster traps plus R30 insulation above the suspended ceiling. After adding each treatment I made waterfall measurements with REW. I was very successful in getting rid of ringing in the 60-100Hz range and made a small improvement in the 26Hz mode of the room. Again, the difference in the sound of the system was amazing.
I don't want to discourage you. Trapping makes a huge difference in most rooms. I just want to make you aware of the limits of traps in the 20-30Hz range.
Hug your pet today!
hjones4841 is offline
post #3 of 3 Old 07-24-13, 09:43 AM
HTS Senior Moderator
bpape's Avatar
Bryan Pape
20-30 is pretty tough to do. I would say that with the right treatment you can impact waterfalls down into the mid to upper 30's. It takes some pretty thick treatment and a decent amount of surface area but it can be done. You can also get into tuned membrane absorbers but again, going that low you need a decent amount of them and they are pretty narrow in function.
Bryan
Bryan Pape
Lead Acoustician
bpape is offline
20hz100hz , tackling , waterfall
