| Home Audio Acoustics Tile Floors?Discuss Tile Floors? in the Home Theater Installation and Systems forum; Tile Floors? Will Paradigms (Sig 6 or Studio 100) sound bright in a room with tile floors?
Should I go with a ... |
| | #1 (Link) | |||
| Tile Floors? Will Paradigms (Sig 6 or Studio 100) sound bright in a room with tile floors? Should I go with a warmer, neutral sounding speaker like B&W 804s? (I think these and most B&W's are overpriced, have read many posts @ various forums they are difficult to drive, are finicky with room placement, and take 6 months to break in!) I had decided on the Pdigms Sig 6 v2, but started researching room acoustics and I have heard, even from another member here that just bought the studio 100 v4, that some material can sound bright, but he tempers this w/ the EQ in his receiver. He has hardwood floors with similiar furniture and area rugs. I have a 25x15 tile floor family room, I do have about 60% of it covered with a large, thick area rug with a pad underneath it, and a large wrap around leather sectional that can sit 10 people easily. Main listening postion is 14 feet from my plasma- rug, leather sectional start about 3-4 feet from current polk R50 entry level speakers, center and sub. 1/2 the ceiling is 10 feet high but then the other half to 25 feet with 2 skylights in a cathederal setting. Also, 8 feet to the right of my set up is a large paladium window, to the left open to a harwood floor living room, directly back of the sectional is a 4 foot wall that separates the family room where the HT is, to an open kitchen with more tile floors In essense I have 2300 sq feet downstairs, open floor plan that is 60 % tile and 40 hardwood floors, I do have lots of wall hangings, the speakers are no where near any side walls and I have soft treatments spread throughout. The living room has french doors but we keep them open, and the wife will demand they stay open! My 7 yr old entry level polks sound good, really good @ times, and they are no where near the caliber of the speakers and $ I plan to spend, and I do have room treatments, but this is an expensive investment and there is no harm in expressing my concerns and getting some feedback. After deciding on the Pdigms, I am now back to the B&W's as they are neutral and warm, but I prefer more dynamic speakers (don't pounce B&W owners, yes, B&W speakers can be dynamic and detailed), but the 804s might be perfect for my, I guess, "bright" room? Appreciate any feedback fellow audiophiles. | |||
| | #2 (Link) | ||||||
| All loudspeakers will sound bright in a room with a bare tile floor. ![]() Quote:
![]() Quote:
--Ethan RealTraps | ||||||
| | #3 (Link) | |||
| Re: Tile Floors? I couldn't agree more with everything Ethan just said. Buy something accurate and fix the room. Don't try to buy something 'soft' because you have large windows and tile floors. If you ever go anywhere else, you'll be buying again. Also, buying 'soft' rolled off speakers isn't going to do anything to deal with the bass decay time in the room which is one of the biggest problems in untreated spaces. Bryan | |||
| | #4 (Link) | |||
| Re: Tile Floors? Ethan, Thanks for the reply. I have various pictures, art, basically there is no wall that is bare. Area rugs, big one's in every room as well as leather furniture in the living room. I am running a basic entry level system, yammie RXV1400, Polk R50, Polk Center and sub, all appx 7 years old, sounds great, rarely bright so I do not think I will have an issue, but you never know, and I plan to purchase a multi channel power amp, willing to spend $1k-$1500 when I decide on the speaks. I do not think I am interested in doing any "real acoustical" treatment I can tell you my wife is not either. We love the way the house is decorated and I am not gonna by some cloth or other soft material to cover the exposed paladium window, defeats the purpose, the skylight are 25 feet away, up in the air The closest side wall to my system is about 14 feet away and I have pictures on it as well Flanking my system to the left speaker is a large, stone/masonry fireplace and the stone goes up to the ceiling Perhaps it will help if I post some picks of my room when I get home in a few hours Anyway, how much difficulty can I really anticipate if my Polks sound good? Thx again. | |||
